1981 f250 2wd long bed with 4.9l i6
It says it is for a v8 not the 300 six.
Are you looking for the line from the pump to the front / side tank? or The pump to the tank switching valve? or The pump to the rear tank? Is this for a 100 point trailer queen never to see the road or looking to replace a leaking line and get it back on the road? If the later then I would hit up Ebay or Amazon for a coil or 5/16" copper / nickel tubing. If you dont have a small tubing cutter pick one up and maybe a tubing bender but you should not need the bender and the tubing is easy to bend by hand. Being C/N it will not rust out like the factory steel one. Dave ---- |
For some reason it made my post into two different threads. I’m trying to replace the hardline that runs along the frame. I know it says it’s for a v8 I didn’t know if they happened to be the same my truck has a single tank
Originally Posted by 1981custom
(Post 21065684)
(Post 21066120)
Make your own line. Much easier.
(Post 21066149)
If I run copper nickel line how do I make my connection to the rubber line just use hose clamps?
Dave ---- |
You may find local help at the auto parts store. My local NAPA guys knew exactly what I needed, it's not like that are not a lot of these old trucks around, that people need to fix.
(Post 21066149)
