No Start - Maybe PATS, Control Module or Something Else?
Hi Everyone,
This looks to be a great community you've built here. I've been perusing the forum to help troubleshoot an issue I'm experiencing but keep coming up short and was hoping someone might be able to offer a bit of guidance or help be a sounding board. I have a 2013 F-150 Platinum with a 6.2L engine. Truck was running well and then I had an issue the other day with it not starting (power cycles on ok, no crank). I fiddled with the ignition on and off for a few minutes and played with the battery in the key, and presto she cranked up and ran perfectly. Got in to go to work in the AM and fired up like a charm so I figured it had something to do with the key battery (I've since learned that this would not have been the case). Went to drive home from work and now it won't start at all. Seems to power up ok but I can't get the engine to turn over. It's throwing quite a few error codes which has me confused on where to start. I suspect maybe some of these codes are related:
Edit to add my current top suspects:
Nick |
If it's a genuine PATS-only event, you should be seeing either a "starting system fault" message on the cluster or a fast-flashing PATS indicator, depending on how the truck is equipped. You didn't mention such an obvious indication.
Originally Posted by projectSHO89
(Post 20701897)
Originally Posted by gromitbeast
(Post 20701900)
Thank you ProjectSho. That's a good point. I'm not receiving either of those flags.
1. What was used to pull the codes? 2. From which modules were each of those codes pulled in the first grouping? Since the running boards have been deleted, all of those codes can be ignored. |
Thanks again ProjectSho.
1. What was used to pull the codes?OBD Link MX+ over Bluetooth to ForScan2. From which modules were each of those codes pulled in the first grouping? I updated in the original thread to include this information.. Update from today so far. I reset the DTC's and am left with the following 2 codes:
Likely Resolved - Replaced Starter
After some additional work on it. Looks like the issued was (*fingers crossed*) the starter. Replaced the starter and all seems well for now. Thanks everyone, and I'll check back if this resolution doesn't prove out.
