2 week wait to be seen.....
Just left the dealership and had to schedule an appointment to be seen that could take about 2 weeks before they can get me in and then they need to keep the truck for at least a few days.
A few things I need looked at/ worked on.. First Oil Change Enable OCR When you slow down and the speedometer gets to around 3-4 mph, the truck seems to slightly “jar” back and forth slightly until you stop. Driver Seat shifts around a little when turning corners. Passenger mirror squeaks when it folds in/ out. Steering wheel is crooked at the 11 o’clock position. Wanted to see if they could put DiElectric grease on all electrical fittings near rear tire to prevent future issues. |
I’d do the oil change myself and go ahead and grab a tube of dielectric grease and get those connections too while under the truck changing the oil. Also, with Forscan you can enable the OCR. I heard some dealerships will do that for free but also some charge for it… either way Forscan allows you to make a lot of changes for free (once you buy the cable). It would be worth looking into. There is already a 2022 Forscan thread started here and over at the Ford Tremor forums.
There have been times of the year when my local dealer has been 1-2 weeks out for just an oil change, but the next dealer 30 minutes away has next day openings. If this dealer is your only choice I would consider doing like suggested above, do as much of it as you can yourself. Then maybe they will only need a day to address the other concerns. It's not the 2 week wait that would bother me, but more so the leaving the truck for a few days.
I'd check around. I had that happen too (3 weeks in this case) so I basically told 'em to f-off and took it to another dealer. I had been dealing with them for a few years with 4 different trucks so it's not like we didn't have a history. Being in Florida you must be close to more than one Ford dealership. Good luck.
Guess I'm lucky living in a rural area. Had a couple small issues and needed an oil change. Called dealer and was in 4 hours later. Waited there and left 90 minutes later.
