Limited-Slip Options for 20-21 F-350
Question:
I was looking for an axle guide for what is actually installed on the 2020-2021’s. Did a search and nothing came up, but seems the search looks at both words even if using quotations. Mainly looking for what is the 4x4 axle are in the F-350 non-Tremor 12,400# GVWR. Would like to know if it feasible to install LS on front axle? I ordered with the 3.31 E-locker option for rear. |
Front or rear?
Originally Posted by BillyE
(Post 19542617)
Front or rear?
Would still like to understand design of both, but can’t seem to find anything that’s in-depth. |
It’s a Dana 60. 35 splines, reverse rotation. There’s every style LSD or locker you could want. You need to decide first if you want an LSD, an auto locker, or a manual locker. There are pros and cons. Serious off-roaders usually prefer manual lockers.
(Post 19542671)
Many list 2017+ and don’t trust when it’s just the “+” so wanted to ensure there wasn’t a change at some point. I have a Truetrack for the Dana 44 in the Bronco and it worked well. Thank you for the info and that makes things much easier! Cheers |
What BillyE said is correct. Dana 60 front axle. 35 spline axle shafts. Tons of options available. I plan to put a Detroit True Trac in mine when it arrives.
Originally Posted by GNR22
(Post 19542682)
