I bought the RONIN oil drain plug... REVIEW
I bought the RONIN Factory drain l oil drain pan plug and did a full review. For those unware, the yellow one from Ford is a pain. This one tries to lessen the pain of changing your oil. It gives a controlled flow, has magnetic tip in the pan and it looks good.
Unfortunately it also helps to lighten your wallet quite a bit too This is on my F150, but my understanding is some new Superdutys also have this plug design, so I thought I'd share it here too. I am quite happy with it. |
Nice review, but my 2018 diesel does not have a plug like this. Is this the gasser design?
Originally Posted by wicked 2018
(Post 18747013)
Any thoughts about the Fumoto quick drain versus this one?
Originally Posted by BOSS 379
(Post 18747019)
However, Fumoto doesn't make a valve for this drain plug yet. Or rather anymore. They used to but it was a failed design that they no longer sell. Supposedly they are working on a new one, we will wait and see. That is not to say that this is not a good drain plug. This is a very well-made high quality product. I just wish I didn't have to use an adapter piece that I will probably lose. |
Neither one of my 6.2s had that type of drain plug. (See signature) And I think I’m glad too.
Well perhaps I was misinformed. Be glad. I'd much prefer a bottom mount metal plug.
Originally Posted by A/Ox4
(Post 18747104)
For $80, a drain plug is going to have to fetch me a beer or something while I wait for the oil to drain. That's just wildly egregious.
I haven't tried the Fumoto, but I did install a Unique oil drain plug ... https://www.uniquetruck.com/category...il-drain-plugs
I have not been impressed with the Unique because draining the oil took almost 30 minutes. Looking at the video above, I dare say its flow rate would also take a long time to drain a diesel's engine oil (assuming one is available for the diesel). I'm going back to my OEM 6.7L drain plug. |
Originally Posted by cficare
(Post 18747385)
(Post 18747013)
Though if I wasn't so cheap I'd get another Fumoto with nipple. Install tygon tube and drain into jugs, easy peasy. |
Originally Posted by Chinookman
(Post 18747398)
Originally Posted by TCNashville
(Post 18747553)
Chinookman could you elaborate on this process? I make a mess every time I change the oil on my 6.2L. Thx.
https://www.fumotooildrainvalve.com/...modelId=582023 Once installed a piece of tygon is placed over the nipple and into a drain jug. Once jug is filled use the lever to close off, get another empty jug and repeat until pan is drained. Hope this helps. |
I have a fumoto on my 2017 6.7 and really like it. Mainly because I don’t need any tools to change my oil. Just a drain pan. Plus it’s potentially less messy, although I have not used it with a hose.
