gootz4u |
06-21-2019 01:14 PM |
My Truck won't engage gear until 200 rpm
Hello all, I hope this is the correct thread to post this, I have a 1998 F250. I just put new timing changes and oil pump. I took the oil pan off, I took the valve covers off and of course, the timing cover. I put everything back together and I turned the key to turn it on. It started right away, it is idling really nice, but then when I put it in reverse gear, it didn't move until the rpm went to about 200, then it engage. I put it in drive and the same thing. I am scratching my head because am not sure if this has to do with the timing. This was my first timing job that I had ever done, but the engine turns on right away. Then, decided to take it around the block and once I pressed the gas and it reached 200 rpm, it engaged in gear and started driving, but I notice that once I let my foot of the gas pedal, it would do it again. Before I did the timing chain job, I didn't have any problems like this. Something to add here also, is that the truck had been sitting and not moved for about a year. I did some research and the only thing I found was that it may be low on transmission fluid. I am going to change the filter and put new fluid over the weekend. Any information would be greatly appreciated and thank you in-advance.
