My Truck won't engage gear until 200 rpm
Old 06-21-2019, 01:14 PM
gootz4u
gootz4u is offline
gootz4u is starting off with a positive reputation.
Hello all, I hope this is the correct thread to post this, I have a 1998 F250. I just put new timing changes and oil pump. I took the oil pan off, I took the valve covers off and of course, the timing cover. I put everything back together and I turned the key to turn it on. It started right away, it is idling really nice, but then when I put it in reverse gear, it didn't move until the rpm went to about 200, then it engage. I put it in drive and the same thing. I am scratching my head because am not sure if this has to do with the timing. This was my first timing job that I had ever done, but the engine turns on right away. Then, decided to take it around the block and once I pressed the gas and it reached 200 rpm, it engaged in gear and started driving, but I notice that once I let my foot of the gas pedal, it would do it again. Before I did the timing chain job, I didn't have any problems like this. Something to add here also, is that the truck had been sitting and not moved for about a year. I did some research and the only thing I found was that it may be low on transmission fluid. I am going to change the filter and put new fluid over the weekend. Any information would be greatly appreciated and thank you in-advance.
Old 06-21-2019, 01:20 PM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
Wouldn’t think about it too much until the transmission fluid is full, as that may solve your problem
Old 06-21-2019, 03:10 PM
gootz4u
gootz4u is offline
Thank you seville009 for replying. I will change it out this weekend. Hopefully that will fix it.
Old 06-23-2019, 10:10 AM
alloro
alloro is offline
alloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant futurealloro has a brilliant future
200 or 2,000 RPMs? Did you possibly dent or kink one of the cooling lines going to the radiator during the timing chain/ oil pump repair?
Old 06-23-2019, 11:24 AM
gootz4u
gootz4u is offline
Thank you for replying alloro, oh sorry, 2000 rpm, I do remember placing my boot accidentally on the lines, hum, I will inspect the lines. I didn't think about that. I had done one final inspection before I had started it to make sure everything seemed in order, Thank you for pointing that out.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
