2011 F150 5.0 KNOCK Cylinder Distortion/Piston Slap Options
I posted this in the 09-14 forum and got some views but no responses so I thought maybe someone in here had experience with this:
"Hey Everyone, I'm new to the forum, not long ago purchased an F150 truck and I love it except for one thing. It's a 2011 with the 5.0 coyote and I have diagnosed it to have the cylinder distortion issue on #3 causing piston slap (has knock when warming up). No other issues yet as it only has 68k miles (no excessive oil consumption, loss of power, misfires etc.). However, I do want to be prepared to take action if/when judgement day comes and it loses cyl #3 as it is out of warranty (unfortunately purchased it this way, relatively quiet knock most of the time). So my first question to anyone who has experience with this is, is this a longevity issue? Will it ever affect my truck in any other way than a sound? I believe the only way to fix the issue for good is a new engine and I really do not want to shell out 3800 for a brand new short block from Ford plus labor so I would be getting a scrapyard engine out of a wrecked truck. The question is, can I use an engine out of a 2013.5-2014 truck in my 2011 without modification to avoid my new(used) engine having the same exact noise when I crank it up? So in your opinion, what should I do with this thing? I love the truck and I'd want to fix it if I have to." |
Hey Man, I think im in the same boat as you, and are looking to find out about the same things.
I posted about it here: https://www.ford-trucks.com/forums/1...ine-knock.html |
Originally Posted by Freek Hammink
(Post 18729402)
I posted about it here: https://www.ford-trucks.com/forums/1...ine-knock.html Sure enough the day I brought it home I heard it, like you. One saving grace for you and maybe me is, you have 100k on yours and the noise is relatively the same and I don’t hear of many of these engines coming apart so maybe they’ll go awhile like this. |
I also do think they can last pretty long, but I also fear that in the end either the piston or cylinder wall will have worn down to much so it will break.
For now i'll ask a tuner to raise my idle rpm just slightly enough so I wont hear it anymore, and I will start putting some money aside for a stroker kit with oversized pistons or something so I can rebuild the engine later. Let me know if you find out new things or if your situation changes |
Okay, same goes for you, let me know if your engine rebuilder says it’s rebuildable.
I think it’ll lose compression one day on that cylinder and it’ll start missing due to the excessive cylinder wall/piston wear; who knows when that day will come, could be next month or could be 100k miles from now. So I agree, I’ll also be putting some money aside for when that day comes. Such a shame that I need to be thinking about a rebuild/engine replacement on my 70k mile truck. |
