Brake pulsating when slowly stopping 7.3 f350 dually 4x4
I have a situation with my 99 f350 dually 7.3 4x4. When im stopping especially in a turn (like parking spot) the pedal pulsates. I almost hit a fence at work, worried i wont be so lucky next time. I put my whole weight on the pedal....it rolled approx 3 feet further than i wanted it to go. There is also a crunchy sound. I have owned the truck for two years. Previous owner said he disconnect the abs on the front. Abs Light comes on usually after rain. The front end was rebuilt when i got the truck (new everything) Brakes have 15kmiles on them.
If the abs is disconnected, can the abs sensor still cause problems? Thanks John |
First of all, I'd reconnect the ABS...
Second, does your power steering whine? It may be time for you to flush the powerboost system (supplies power assist to both steering and braking) |
The power steering does not whine.....but that is a thought.
When you say abs, are you referring to the sensors in the hub? |
I just went outside to check if they were disconnected....are they were not, they were connected...
Originally Posted by Crownvicguy
(Post 18688361)
Could be cruddy fluid, bad pump or Hydro boost If you have the previous owners information I would call him and see what he did. You should not be getting ABS lights. |
Im actually taking the truck to a shop that strickly does front end, suspension, brakes, tires, shocks, etc.....on friday......is this something that would be in their wheel house?
I had it happen going straight at stop at a stop sign this morning. The last two feet or so the truck tried to pull to the right.
Here is what i have done
Changed rotors, pads, calipers on front and rear Changed fluid in power steering pump with mercron 5 Changed the hydro boost My pedal still randomly gets hard to press and for a few seconds ill have no assisted braking unless the release and press again. |
