2000 f350 crank but no start
So I’m new here, Bear with me lol. I just bought this truck two days ago, has the 7.3 and yesterday it was driving just fine or what seemed to be fine. Left a stop and it started stuttering and felt like a misfire, no power. It started to clear up but came back. Tried getting it down the road but no acceleration at all so I stopped it. As soon as I stoped it died right away. Made me think it was out of fuel so I put more in it. It will crank and fire on either but it will not run on it’s own power. Looked into the fuel bowl and it had fuel in it. Unplug the icp sensor. I have a tachometer so I know the cps is fine. When I looked at the oil level it was dark so I couldn’t really see. Just wondering if any one can shot me in the right direction. Completely new to diesels
First off no ether. EVER
The glow plugs can light it off way before top dead center, it burns hotter than our aluminum pistons can safely handle, just a bad idea all around. Since you already tried with icp unplugged, try unplugging the fuel bowl heater and replacing fuse #30 under the dash. Check to make sure the ipr tinman nut is tight. You said you put more fuel in it, what's the gauge read? 1/4 or above? |
Originally Posted by Wesley Green
(Post 18677957)
The glow plugs can light it off way before top dead center, it burns hotter than our aluminum pistons can safely handle, just bad idea all around. Since you already tried with icp unplugged, try unplugging the fuel bowl heater and replacing fuse #30 under the dash. Check to make sure the ipr tinman nut is tight |
First suspect would be the in tank fuel pick up. Research Hutch Mod. pull the hose off the rear of the fuel pump, which is under the driver's seat and blow air back into the fuel tank to knock any debris off of the fuel pick up. You don't need a lot of air and remove the fuel cap first. There's a white, plastic horseshoe retaining clip that holds the line on, then it just pulls off. Those clips tend to break so get new one(s) before operating. There are two sizes and you want the white ones, not the black ones for this spot. Put more fuel in and try again.
As Walleye mentioned above, this is likely your problem. If you do push compressed air into the tank in an attempt to clear the line, be sure to remove the fill cap first.
Also, here is a link to my hutch/harpoon mod adventure. Years later this is still one of my favorite mods completed. https://www.ford-trucks.com/forums/1...ne-almost.html |
Originally Posted by Walleye Hunter
(Post 18678012)
Have you added more fuel? Did fuel come out that hose while it was off?
(Post 18679141)
There is a block heater. The element sits in the housing next to the filter and the cord for it should run up the frame and plug should be somewhere around the front end, driver's side. Try plugging it in for a few hours and see if that helps. BTW, the 7.3 does not like to be run out of fuel so if the pickup is broken off in the fuel tank and it was run out it can take a while to get it to start again.
(Post 18679399)
(Post 18679399)
Still no luck. Is there anywhere I can look for fuel getting up to the motor. Still seems like it’ll fire once every few seconds and blowing white smoke
There is a drain on the back of the fuel bowl, it's a plastic, yellow lever that you spin to the right to open. The drain is a steel tube that runs down the front of the block on the passenger's side if it's still intact. You can open that, put a drain pan under the truck to catch the fuel and turn the key on, it should pump fuel out.
If it was the fuel pickup that fell off, mine would have sit there and have seizures for about 30 minutes before it would smooth out and run right again. It would run after fuel was added but could not pull itself.
(Post 18681021)
