Protecting Running Board Finish
Finishing up the restoration of a 1950 F47 Truck and was wondering if there were some ideas out there about protecting the paint finish on the running boards. I am aware of the aluminum step plates that bolt to the running boards. However, I was hoping for something to protect the entire running board from random people stepping on them at shows, etc. I realize that I am being probably somewhat unrealistic, but a lot of hard work and money went into this project. Just want to keep it looking as good as I can for as long as I can.
Thanks for your ideas. |
I have a 56 but I know what you mean. There was too much hard work spent making those running boards look good. I have the aluminum plates on mine- but being 6'4"- I step over the running board right onto the truck floor because I just don't want to touch those running boards! :-)
I try not to use the running boards to get in and out of the cab but sometimes depending on how it's parked I do. But my truck, although nice looking, is not a show truck or a trailer queen. I like to drive it on dry days but if my running boards get too scratched it's easy to remove them and paint them.
I had my 55 F350 painted last year. On the bigger trucks you do need to step on the running boards. I wanted something on them that would not be easily scratched. I researched this here at FTE and online. The consensus was to spray them with a tough undercoating, not bed liner. I am not happy with it. The color came out a dark gray, not black. It is showing some signs of wear. And at one spot a small piece chipped off. So I might take them off and spray them gloss black. I am not sure how that paint will wear overtop the undercoating..... |
Originally Posted by 100550dvr
(Post 18605286)
I had bought new re-pops for my truck. I took them in and had them Powder Coated gloss black along with the bolt heads. Not impervious but still looks good after 3 years.
https://cimg7.ibsrv.net/gimg/www.for...837dde4ebf.jpg |
I found and have been using KBS-Coatings. They are brushable, sprayable, and more durable than powder coating. at least that's what they claim. So far, I am happy with the results. you can hit the frame with a hammer and it doesn't chip.
KBS Coatings Website |
Originally Posted by abe
(Post 18605642)
I just thought of another solution, at least at shows. Denny, First Rider, for his beautiful 52 made long flexible magnetic sheets for his boards. On them he had printed facts about his truck.
After painting they could be covered with a clear plastic film which is used on front facia's and stone chip prone areas . It would eventually scuff but could be redone after time and not damage the paint . There should be no problem finding a shop , anyone doing wraps I would think .
Just don't step on them. They will stay nice forever
Originally Posted by EBEAR
(Post 18606139)
here's my answer but they are gettin hard to find... everyone is backordered... A generous FTE member hooked me up with a pair, or I'd still be waiting..
https://cimg6.ibsrv.net/gimg/www.for...64343fc642.jpg |
Originally Posted by jniolon
(Post 18608350)
https://cimg6.ibsrv.net/gimg/www.for...64343fc642.jpg And the OP has a 50 truck and the gear and lightening bolt is for 53-56. |
Hello, i've seen trucks at car shows that have oak or maple "strips" that fit in the grooves of the running boards just a little higher and the whole length of the groove. I've also seen polished stainless "strips" which serve the same purpose. Looked them up on flea bay, finally found them, and it seems like they were $60.00 Per Strip! Either way would require a lot of penetrations in those running boards. Good luck, larry
X3 for PPF...paint protective film. 3M makes some great films and they even sell a spray-on aerosol version that is easy to apply and re-apply if necessary. Take a look on YouTube, lots of good info and demos.
Originally Posted by 52burjes
(Post 18608966)
Unfortunately I do not have a good picture. This is the best that I have. https://cimg9.ibsrv.net/gimg/www.for...cbd70825af.jpg EDIT: I found one a little bit better. https://cimg0.ibsrv.net/gimg/www.for...b0224774d6.jpg |
