Originally Posted by skuzzybucket
(Post 18604572)
Nice set of 3 bar explorer heads would look purrrdy on there too, and wake that little small block right up. & a set of 1.7 roller ped mount rockers
Just saying Check that old thread of mine out |
Nice!
I built the similar motor for the 94 pickup, but used the 3 bar head, the plugs are still angled on those. I also used a different cam for more bottom end. . still, it's only a 5.0. |
(Post 18605520)
Nice!
I built the similar motor for the 94 pickup, but used the 3 bar head, the plugs are still angled on those. I also used a different cam for more bottom end. . still, it's only a 5.0. I was disappointed but honestly I never put more timing in it or checked a/f. The mustang cam in the heavy SUV might have not been ideal . The mustang cam is small tho. I should have kept that bronco. It was so very nice and rust free. Trying to find the motivation to go stab the mill back in... |
3 bar heads have same combustion chambers, but the spark plugs are angled like efi heads, NOT straight in like the p heads, so they don't require special exhaust.They also don't have the chamber going through them for the A.I.R. pump, so no smog
1.7 roller rockers will give you some "cam" with the stock cam for about $100. Mustang cam comes alive about 3 grand, trucks need the grunt, so you need bottom end. If you decide to build a 5.0, or 5.8 to play with in a truck, let me know, I have a few I played with ,and figured it out pretty good. Even Tom listened to me on one of his 5.0 toys ( not that he will admit it) |
Oh, yea you are correct. I forgot about those.
Well as of about 5 today It is alive. I ran it and got the coolant,ps,oil topped off and it moved it's self out side. Later I'll take it for a test drive maybe. |
Cool. I like that truck. Would look good next to my Centurion Bronco. LOL
Oh, and that one is a C-350, it has a 460 in it. |
https://cimg8.ibsrv.net/gimg/www.for...240193aa3e.jpg
some gnarly ol' freeze plugs https://cimg3.ibsrv.net/gimg/www.for...ead6493bc8.jpg all back in. This was earlier today . I didn't get a completed pic but will tomorrow. It's running well and the wife and I went for a test drive earlier. Winning boys!! Tomorrow seat mod and a driver's mirror swap. Clifford giving up old unused parts... |
(Post 18606878)
Oh, and that one is a C-350, it has a 460 in it. I'd totally rock that! |
Looking good, your going to have a great daily driver!
Now that it's working and reliable,
TURBO TIME |
A couple of things then it's time to work on Clifford!!! Thanks fellas, I am pretty happy to have grandpa to close to 100% .
https://cimg6.ibsrv.net/gimg/www.for...6cbbaa7948.jpg
all like new! On to other fun projects! |
Very nice!
Only thing I can see might bite you later is the vacuum juice can on the fender. It may or may not have rust holes in the bottom, Mine did when it got looking like that. You'll know when you have your a/c on, and hit a hill, it goes to defrost as default Grab one from a 93-96 5.8 truck, they're plastic Also, lookin at your master cyl, you don't have the cruise control fuse recall. take your serial number over to ford, make sure, there is a pig tail harness with fuses that goes in there to keep gramps from catching fire |
If that pigtail is the same on 3/4 ton trucks, I have one in my parts bin.
(Post 18608348)
Very nice!
Only thing I can see might bite you later is the vacuum juice can on the fender. It may or may not have rust holes in the bottom, Mine did when it got looking like that. You'll know when you have your a/c on, and hit a hill, it goes to defrost as default Grab one from a 93-96 5.8 truck, they're plastic Also, lookin at your master cyl, you don't have the cruise control fuse recall. take your serial number over to ford, make sure, there is a pig tail harness with fuses that goes in there to keep gramps from catching fire Yea it's needing done. There is no fluid intrusion that I can see so it's ok till tomorrow. Drove it all around today and it is very well. Pulled the front seats and did some improvement. https://www.ford-trucks.com/forums/1...-seat-fix.html Just like that we did all along Sits even better Next a driver's side mirror, machine front rotors and swap in the LSD I have sitting here. I planned it for the falcon but that's gone and I need a pair of tires turning lol #because5literpowa |
