6.7 Engine Brake and Mileage
Haven’t had my 2019 for long but I remember reading a post a while back that said guys use the engine brake on auto even when empty. I’ve been using it back and forth to work on auto and it works good. I haven’t paid much attention to mileage but will there be a difference in mileage between not even touching the brake and having it on Auto ? Having it off the truck seems to roll a lot nicer What do you guys do for normal commuting ?? thanks matt |
I go back and forth. I drive all day every day for work (I own a service company). I'm probably 60% city, 40% highway/freeway. I use the brake all the time when exiting offramps & allow the engine brake slow the truck down. Same thing in freeway traffic. I've upgraded to the Raptor steering wheel with the paddle shifters, so it makes it a hoot to drive in traffic. I rarely have to use my brakes.
On city streets, I don't use it as much. Just doesn't' seem to engage/slow the truck as much when you're going under 30 MPH unloaded. I average about 16k miles a year on my 350 & average MPG is 13.7. Not breaking any records, but for a 60/40 split city/hwy I'll take it. |
If you're trying to maximize mpg don't use the EB unless you need it. Anything that impedes coasting is costing you fuel.
Have any of you tried the engine brake towing a trailer or a heavy load? I have a brand new F350 and haven't towed yet with it. I had an aftermarket engine brake from Banks in my 2005 Dodge Cummins. It worked very well.
I'm wondering how the performace is with this OEM built in engine brake system. I tow a 44' Toy Hauler (heavy - 16K). Does it work by tapping the brake? Does it hold the speed on a downhill decent? |
Originally Posted by MBaldo
(Post 18541354)
I'm wondering how the performace is with this OEM built in engine brake system. I tow a 44' Toy Hauler (heavy - 16K). Does it work by tapping the brake? Does it hold the speed on a downhill decent? Note: I would say that it not just strictly an engine brake. More like an engine brake management system. When the going gets really steep I've seen the transmission kick down in conjunction with the engine brake to maintain speed. |
Originally Posted by wrvond
(Post 18541389)
The first press turns on the engine brake, the second press puts it in auto. In manual, the brake is set to whatever speed you are traveling at the time, auto doesn't do anything until you press the brake. Whatever speed you are going when you release the brake is what the auto is set at. They both work quite well. I go through Rocky Gap quite often, last week it was snowing, and the brake holds speed quite well pulling even the heaviest 5er.
(Post 18541354)
Originally Posted by 2009kr
(Post 18541652)
I'm just over 26k# loaded with my 5th wheel. With the engine brake on auto, it'll hold 65 on a 6 5% mountain descent around 2600 RPMs in 5th (2017 F450).
The '19 F350 is my first experience with the Engine Brake. I was very happy with the auto function while descending a snowy grade recently pulling my snowmobile trailer at slower speeds. As wrvond mentioned, it seemed to work in conjunction with the transmission to help maintain speed without the need to touch the brakes.
(Post 18541789)
Good to know Do you think it would hold you at say 35 mph on a steep downgrade if you pushed twice on the brake to set the speed?
Originally Posted by mtnguy
(Post 18542925)
On the curvy 7-8% grades around here, I will manually shift the tranny into 3rd, and the engine brake (in manual mode) holds the speed with a 12,000 lb 5th wheel pushing me down the mountain. I still need to apply brakes a bit on the sharper turns. the reason I do a manual gear selection is so that the tranny will not shift to 2nd automatically when I brake for the slower curves. The engine brake works great !! :-jammin
I've heard that using cruise control on icy/snowy roads is a bad idea so I would think that using the exhaust brake while descending icy/snowy roads could come with some surprises if you hit a slick spot.
If you do use the exhaust brake in situations where traction is less than optimal, does the exhaust brake turn off once a loss of traction is sensed? |
Yes, the traction control traction control and sway, yaw control do work, however, with a total loss of traction, bad things can happen. I don’t use cruise, but I do use engine braking in moderation on slippery roads. You do have to be ready to disengage it. on the mileage, in my experience, and I am at 46,000 km, engine braking makes no difference in fuel mileage over the longer term of a tank full of diesel. I have done comparisons with none, and full, and auto and can’t detect a difference on total distance travellled for the same trip. I stopped comparing about 30,000 km ago, and use the EB nearly 100% of the time. |
Its an exhaust brake (not an engine brake)
There's a big difference
Has anybody found a way to make it so the exhaust brake comes on automatically when you start the truck? Our ambulance is around 16,700lbs, so we prefer that our drivers use the exhaust brake to help save the brakes a little when clearing intersections or during normal driving. We find it also gives our patients and providers a smoother ride in the back as there is not constant brake pressure being applied. It is a hassle to remind everyone to press the button before every call. The internationals we just moved from had a simple on/off switch.
