6.7 Serpentine Belt Change
My 2011 F250 w/6.7 (May 2010 build) is getting a bit long of tooth and needs some TLC
At 117,000 fairly easy miles, it is about time to change the serpentine belt. I've looked at some generally useless You Tube videos and have done a search here with little real information beyond a good belt routing drawing. OK, the truck is pretty garden variety - single alternator, Replacement belt from Rock Auto for a Motorcraft is about $75 bucks, Gates and Dayco are somewhat less. Is there a decent 'How To' anywhere? Has anyone here come up with a good DIY method? It looks like the fan shroud upper, air cleaner box top and probably the CAC to inlet tube needs to be removed at a minimum - but .... |
Here is a youtube video from Arod. I think he has more off of the engine than is needed but it gives a good view of belt routing etc. Like I said, you don't have to take this much off, but he did so it showed up good.
Originally Posted by 254XP3
(Post 18531759)
Here is a youtube video from Arod. I think he has more off of the engine than is needed but it gives a good view of belt routing etc. Like I said, you don't have to take this much off, but he did so it showed up good.6.7 Powerstroke Belt Replacement
The technique used by the gentleman in this
Originally Posted by ILBCNUL8R
(Post 18534035)
The technique used by the gentleman in this video definitely shortened the time it took me to do the job the first time. The keys for me were removing the sensor bolt (it's a long one) and inserting the doubled belt from the top to get started.
To change the belt, it takes a 1/2" breaker bar for the tensioner, that's it.
With that many miles, I'd suggest replacing the tensioner and two idler pulleys at the same time. I always do that when changing serpentine belts because those are cheap parts compared to the radiator or CAC if the tensioner comes apart (which has and does happen). It was less than $150 for all motorcraft parts when I did mine. |
Originally Posted by saratoga2011
(Post 18535919)
With that many miles, I'd suggest replacing the tensioner and two idler pulleys at the same time. I always do that when changing serpentine belts because those are cheap parts compared to the radiator or CAC if the tensioner comes apart (which has and does happen). It was less than $150 for all motorcraft parts when I did mine. Update:Ordered a belt, a tensioner and 2 idler pulleys from Rock Auto - and over $200 with a Gates belt amd Motorcraft items. Previous history with belts is that Gates have worked best for my needs vs Motorcraft. |
(Post 18531759)
Originally Posted by DeeDubz
(Post 18538253)
That video is good but is deceiving. I changed my belt about 6 months ago. It was a PIA. On my truck there's a small piece of plastic that connects to the block of the motor and the fan clutch. Making it impossible to put the belt on without taking it off. I'll try and post pictures later. I had to take a few bolts off... not a huge deal but I watch a few videos with not one having this issue.
Hope you can post your photos. |
Originally Posted by Irelands child
(Post 18539511)
Was that the fan sending sensor? Suspect that's what it was and something that I saw somewhere.
Hope you can post your photos. I believe so, Heres the picture. Its the Black bracket looking thing toward the top of the photo. Not the best but that's what I had to deal with. anyone know the trick without taking this thing off? |
(Post 18540247)
Hold the phone... Replacing the belt at 117k miles and 2011 model? Is that norm? Seems kinda early... I had an 06' with 130,000 miles and belt appeared to be in excellent shape.
Originally Posted by Batman7777
(Post 18541653)
1 Attachment(s)
Obviously it's neither easy nor fun on a 6.7L, but no need to overthink it. . . If it'll help, attached is the procedural description from Ford's Workshop Manual.
