6.7 Serpentine Belt Change - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-10-2019, 01:07 PM
Irelands child's Avatar
Irelands child
Irelands child is offline
Irelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to behold
My 2011 F250 w/6.7 (May 2010 build) is getting a bit long of tooth and needs some TLC
At 117,000 fairly easy miles, it is about time to change the serpentine belt. I've looked at some generally useless You Tube videos and have done a search here with little real information beyond a good belt routing drawing.
OK, the truck is pretty garden variety - single alternator, Replacement belt from Rock Auto for a Motorcraft is about $75 bucks, Gates and Dayco are somewhat less.
Is there a decent 'How To' anywhere? Has anyone here come up with a good DIY method? It looks like the fan shroud upper, air cleaner box top and probably the CAC to inlet tube needs to be removed at a minimum - but ....
Old 03-10-2019, 04:18 PM
254XP3's Avatar
254XP3
254XP3 is offline
254XP3 is starting off with a positive reputation.
Here is a youtube video from Arod. I think he has more off of the engine than is needed but it gives a good view of belt routing etc. Like I said, you don't have to take this much off, but he did so it showed up good.
Old 03-11-2019, 08:41 AM
Irelands child
Originally Posted by 254XP3 View Post
Here is a youtube video from Arod. I think he has more off of the engine than is needed but it gives a good view of belt routing etc. Like I said, you don't have to take this much off, but he did so it showed up good.6.7 Powerstroke Belt Replacement
Thanks. Yep, saw that one and found it virtually useless as he has pulled way more off then I believe necessary including the fan for a belt change out. I do have a Ford TSB that shows belt orientation which should work well.
Old 03-11-2019, 05:45 PM
ILBCNUL8R
ILBCNUL8R is offline
ILBCNUL8R is starting off with a positive reputation.
The technique used by the gentleman in this
definitely shortened the time it took me to do the job the first time. The keys for me were removing the sensor bolt (it's a long one) and inserting the doubled belt from the top to get started.
Old 03-12-2019, 07:07 AM
Irelands child
Originally Posted by ILBCNUL8R View Post
The technique used by the gentleman in this video definitely shortened the time it took me to do the job the first time. The keys for me were removing the sensor bolt (it's a long one) and inserting the doubled belt from the top to get started.
Thanks. I saw this one as well. It almost makes me motion sick with the camera bouncing around but his hint about doubling the belt is good info
Old 03-12-2019, 02:09 PM
saratoga2011's Avatar
saratoga2011
saratoga2011 is offline
saratoga2011 is starting off with a positive reputation.
To change the belt, it takes a 1/2" breaker bar for the tensioner, that's it.
With that many miles, I'd suggest replacing the tensioner and two idler pulleys at the same time. I always do that when changing serpentine belts because those are cheap parts compared to the radiator or CAC if the tensioner comes apart (which has and does happen). It was less than $150 for all motorcraft parts when I did mine.
Old 03-13-2019, 06:30 AM
Irelands child
Thanks. Breaker bars - I have. Tensioner and idlers - probably a good idea as well. I've had my problems with other Ford products with them and not all high mies either Guess I'll put my Rock Auto order together and have the parts when (if ) it warms up enough to do this project along with a trans oil change a secondary radiator flush that has material waitng since fall,
Update:Ordered a belt, a tensioner and 2 idler pulleys from Rock Auto - and over $200 with a Gates belt amd Motorcraft items. Previous history with belts is that Gates have worked best for my needs vs Motorcraft.
Old 03-13-2019, 06:04 PM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
DeeDubz is starting off with a positive reputation.
That video is good but is deceiving. I changed my belt about 6 months ago. It was a PIA. On my truck there's a small piece of plastic that connects to the block of the motor and the fan clutch. Making it impossible to put the belt on without taking it off. I'll try and post pictures later. I had to take a few bolts off... not a huge deal but I watch a few videos with not one having this issue.
Old 03-14-2019, 09:29 AM
Irelands child
Was that the fan sending sensor? Suspect that's what it was and something that I saw somewhere.
Hope you can post your photos.
Old 03-14-2019, 05:02 PM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
I believe so, Heres the picture. Its the Black bracket looking thing toward the top of the photo. Not the best but that's what I had to deal with. anyone know the trick without taking this thing off?
Old 03-14-2019, 05:42 PM
Irelands child
Thanks for that photo. The weather was good enough today (53*) for me to take a better look at what has to be done. My guess is that the neighborhood kids had best not be nearby as my language can get interesting. My truck is an '11 and a very early JOB 1 and seems to have a couple things in the way that others I've looked at may not have. Gonna be interesting and may even take a couple picture for others to look at but no promises. Looks like I might need scaffolding to reach in there even though I'm 6' 4" tall.
Old 03-15-2019, 12:37 PM
Batman7777
Batman7777 is offline
Batman7777 is starting off with a positive reputation.
Hold the phone... Replacing the belt at 117k miles and 2011 model? Is that norm? Seems kinda early... I had an 06' with 130,000 miles and belt appeared to be in excellent shape.
Old 03-15-2019, 03:50 PM
Irelands child
The belt may be just fine but when you are hauling a 12,000 pound, 38 foot 5th wheel, you don't need a belt to 'pop' on a Saturday evening 100 miles outside of East Overshoe in an almost unpopulated Midwestern state. The '06 that I owned was a V10 and that belt was shot at ~80,000 miles but was a heluva lot easier to change
Old 03-15-2019, 05:40 PM
ILBCNUL8R
Obviously it's neither easy nor fun on a 6.7L, but no need to overthink it. . . If it'll help, attached is the procedural description from Ford's Workshop Manual.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
