1978 C7000 brake master cylinder (10.4 liter CAT)
Separated brake master from reservoir and found that i have inside bore of 1.75"....can only find 1.5" bore replacements. Seems like a perfect match otherwise, so maybe this is the right replacement afterall?....anybody have insight on this?
Originally Posted by bakerant
(Post 18491689)
Seems like a perfect match otherwise, so maybe this is the right replacement after all? :-huh So, the 1 1/2" bore is not a replacement for the 1 3/4" bore. I need the AXLE code (stamped on the Warranty Plate) to determine what the correct 1 3/4" Ford part number is. btw: C7000 is a C700 with a diesel. And...the C series is a Tilt Cab. |
