1978 C7000 brake master cylinder (10.4 liter CAT) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Reload this Page >
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 02-19-2019, 09:05 AM
bakerant
bakerant is offline
bakerant is starting off with a positive reputation.
Separated brake master from reservoir and found that i have inside bore of 1.75"....can only find 1.5" bore replacements. Seems like a perfect match otherwise, so maybe this is the right replacement afterall?....anybody have insight on this?
Old 02-19-2019, 12:26 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Seems like a perfect match otherwise, so maybe this is the right replacement after all?
1973/79 C600/900 with hydraulic brakes: There are THREE different master cylinders, one has a bore of 1 1/2" the other two have a bore of 1 3/4."
So, the 1 1/2" bore is not a replacement for the 1 3/4" bore. I need the AXLE code (stamped on the Warranty Plate) to determine what the correct 1 3/4" Ford part number is.
btw: C7000 is a C700 with a diesel. And...the C series is a Tilt Cab.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
