Fan shroud?
Should my 57 F-100 with a 292 have a fan shroud? Thank you. |
Originally Posted by 1957 F100 New Guy
(Post 18355175)
Should my 57 F-100 with a 292 have a fan shroud? No 1957/60 F100/250 or F350 with single rear wheels has a fan shroud. |
Thank you sir. |
Fan shroud
If your water temp has a tendency to go high in the heat of the summer, especially when sitting in traffic, then it's a good idea!!
I'm assuming since dualies (sp) haul more weight they generate more eng. heat?
If I wanted...
Guys, If I want to install a shroud later, would the closest fit be one from a dually of the same year and series? Example, 1957 F-100 - 350 dually? What would you recommend? Matt |
(Post 18372680)
If I want to install a shroud later, would the closest fit be one from a dually of the same year and series? Example, 1957 F-100 - 350 dually? What would you recommend? No fan shroud was available for 1957/60 F100/250 & F350 with SRW (single rear wheels). B7Y-8146-A .. Fan Shroud - Use with DRW (dual rear wheels) - 223/272/292 / Obsolete 1957/60 F350/600 // No Ford dealer or obsolete parts vendor has any. |
Take lots of measurements & hit the scrap yards!!
Thank you everybody. |
