4R75E issue
i have a 08 F150 with 122,000 miles. The trans “clunks” sometimes when upshifting or downshifting. Also it seems like the trans has a nasty shutter when back to the gas between 35-45 mph. These issues aren’t all the time but they are getting progressively worse. I have changed plugs and coil packs and nothing changed. Any suggestions as to the cause? Has anyone else experienced this? thanks guys!! |
Probably due for a fluid change.
The shudder sounds like the typical torque converter shudder this transmission series is known for when the fluid gets worn out. Start there. |
Originally Posted by meborder
(Post 18260808)
I can recall back when they said that this transmission did not need maintenance. https://cimg6.ibsrv.net/gimg/www.for...216715a59d.jpg |
