3 speed manual transmission
While I got the motor and transmission out, I cleaned up the transmission the other day. Should I just replace the seals and gaskets on the transmission or get a rebuild kit? The transmission was working fine when the truck was parked. Thanks.
https://cimg5.ibsrv.net/gimg/www.for...83ea6eba2c.jpg |
You might as well do a rebuild since you have it out of the truck, although i highly doubt it needs one. The top-loader three speeds are some stout little transmissions.
I wouldn't rebuild if it was good previously. Put in new gaskets & seals, prime, paint and be happy |
When you open it up check for any metal in the oil. If it's shiney, rebuild the unit. If not, just do new seals, gaskets and use synthic oil.
To do the job correctly...replace:
Front/rear ball bearings (7025/7065), needle bearings on the input (7118) & counter shafts (7121), 1st gear (1) and 2nd/3rd gear (2) syncro brass blocker rings (7107), front/rear seals (7A283/7052), gaskets (available as a kit). These parts are the same for the Ford type 3.03 3 speed manual all syncro trans from 1963 thru 1987. https://cimg9.ibsrv.net/gimg/www.for...0fbd75bcfd.jpg . |
Thanks everyone for the information.
My x-law fathers in law 66 f100 we hard to replace the rear out put tail shaft bearing that went bad.
Started making noise in second gear rumble sound going slow. With out the proper tools like long arm gear puller etc. you have to figure out how to remove the rear bearing. Orich |
Need help finding a rebuild kit. Catches in second gear. All ready replace linkage rod bushings aligned everything with the drill bit method still catches from first to second. Not a smooth shift.
1970 360 3speed on colum. Any know if a good kit ? https://cimg6.ibsrv.net/gimg/www.for...eb802f2739.jpg https://cimg3.ibsrv.net/gimg/www.for...ac33d6394e.jpg |
Originally Posted by dkj313
(Post 18712697)
1970 360 3 speed on column. Anyone know of a good kit ? https://cimg3.ibsrv.net/gimg/www.for...ac33d6394e.jpg 1970 F100 300/302/360 with 114" wheelbase. |
