Halogen Head Lights
My truck is a 1971 F250 300 inline 6 with a C4 trans. When it comes to head lights I need all the light I can get while driving at night.
I would like to install a set (2) HI Performance Halogen Headlights. Just want to make sure the stock wiring & alternator can handle the change? |
Check out:
https://www.ford-trucks.com/forums/i...isc/sticky.gif Read First: Technical Info Hyperlink Compilation(https://www.ford-trucks.com/forums/i.../multipage.gif 1 2)HIO SilverThere is an article in there about changing the old alternator, and installing a newer 3G version. It's very easy to do. Then your new headlights will have lots of power. I would also suggest doing the relay wiring set-up. |
Do the relays for sure. Then you can get whatever lights you want. Either halogens with clear housings, or performance sealed beams of you want to keep the "old" look.
You can use Halogen lights with your original wiring and alternator but they're better/brighter with the headlight relays. I changed mine to Halogen 30+ years ago.
I first did a 100amp since it was just a bolt in job.
An the price was right for a near new in box chrome for $20 bucks. I had a 70 amp already to feed my dual batteries setup but the head lights an night still faded out some at a stop lights at night when, I had my o/h camper on that had a bunch of clearance lights. But a good noticeably increase in lighting when, I installed 100amp alt. Well dumped the camper after gas went to over $5.50 a gal. So played with doing some upgrades like the 3G 130amp then the replay setup to the Led running lights. But have never checked the lights for driving at night after switching them over. I know they'll be much better then what, I had before.. PS For the head led light bulb upgrade you'll have to cut the head light bucket rear wider hole for the dust boot to fit through the back side like pictured below. I did not like the led beam width that had the" Hey look at me I have the Halo lighting also so went back to the oem style fitting bulbs halogens Orich https://cimg2.ibsrv.net/gimg/www.for...ea50784ca5.jpg |
I have a '70 F100. Did my headlights this afternoon.
Used the Hella Vision Plus conversion kit (165mm) ( ) and a harness I got on EBay (https://www.ebay.com/itm/330997592807). |
Well I did a little headlight checking and found that the last owner had converted the original OEM Ford sealed beams that are a bit yellow at night to a set of Topgear Autosport 7" round Sealed Beam High Reflexer headlight conversion with H4 light bulbs.
As close as I can tell the alternator is 55 or 65 Amp single belt pulley unit. Truck has a single battery, not towing anything at this time, straight AM/FM radio and no Boom Box Speakers. Have not had time to make a night test run as I have been fixing small thinks on the truck to make it more road worthy. Does this conversion look like it may OK for the time being? |
Sounds like they are definitely better than the originals.
Originally Posted by efdavila
(Post 18154779)
Used the Hella Vision Plus conversion kit (165mm) (https://www.amazon.com/gp/product/B001G72SKQ) and a harness I got on EBay (https://www.ebay.com/itm/330997592807). |
The headlights were plug and play. No modifications needed at all.
The harness was pretty straight forward after finding a video to help with the process. Though not the same vehicle this was the most helpful video for me: |
Here is another headlight wire harness...http://www.rccinnovations.com/index....enu-trucks-all Scroll down to HRKU - Headlight Relay Kit, Universal.
Thank you efdavila and LACzar for the great information. I will be upgrading my headlights and wiring soon!
I thought I posted this on my thread but I don't see it.
May I ask you guys a question. Why do I need to install a new head light harness when installing Halogen head lights? |
Simple as basic electrical theory. Halogens consume more amps of which your original wiring harness is marginal with small gauge wire and a marginal light switch, and with it being almost 50 years old, it it is time to upgrade with heavier wire and relays like more modern vehicles use.
Originally Posted by RichS2659
(Post 18157751)
The wiring harness that gets installed with the relays does need to be larger as that part will be carrying more load. The trucks old wiring is then used as a switch to work the relays. Even if you don't go with halogens using the relay and harness will make the stock sealed beams brighter because they are now getting full 12 volts as it only goes from battery to relay to lights. Dave - - - - |
