How long before Limp Mode kicks in when Reductant heater code comes up??
So, I register to the site this morning and my first issue has popped up. I had the engine light come on and hit up Oreilys to get it figured out. My reductant hearer is out. First off I want to know how Long I can drive before limp mode hits. I have a 50/50 warranty on this part. Seems to be a reasonable fix from my YouTube research. Anyone else done this fix OR paid to have it done? 59k Miles, wouldn’t think this would go out!
Thanks all |
I don't think the heater will put the truck in limp mode when the outside temperature is high enough that the DEF doesn't freeze.
I drove for at least two months with the issue, P20BA. It does de-rate performance some but not enough to notice daily driving unless towing or wide open throttle above 2nd gear. If I needed to tow, I would clear the code for that start and it wouldn't trigger again until the next start. $840.82 at the dealer. The labor was as much as the part so if you know how to repair, you'll save at least half.
please forgive my ignorance. But, how do I clear the code? I’m supposed to pull the camper to Iowa with the family this Thursday. I’m a little worried about what COULD happen. My wife would be none too pleased if we had to go 280 miles at 55. Take a lot beer to stave off her killing me.
The reductant heater code won't affect performance and it won't put the truck into limp mode. I drove with it all summer last year before I finally deleted the truck. You can clear the code if you want to turn the CEL off, but it really doesn't affect anything until it gets cold and your DEF freezes. Any code scanner or programmer will clear you DTC codes.
I just noticed this thread, exactly what I was asking on my post. Thanks.
FYI, my cheapo ~$79 harbor fright scanner read and cleared the code fine. |
Ed, there is an FSA on extending the warranty on the DEF heater. Contact your dealer to see if you are covered for free repair.
Originally Posted by Just Strokin
(Post 18055071)
I just got my 18M01 letter from Ford in the mail two days ago. And about a month ago I got the code for the first time. Great timing :)
P.S. The $5 Torque Pro Android app combined with a $15 bluetooth OBDII adapter can also clear codes. |
Originally Posted by Bill Wolf
(Post 18084577)
Yes its CSP 18M01 released in April. Warranty coverage is 11 years or 120K miles whichever comes first and if your over 120K you get to the end of 2018 to have the heater replaced. zget in line, the diesel techs at the dealers are busy!!
Hmm I never got that letter but I threw the code 2 weeks ago and when I went camping lets just say the truck sucked at towing....
Originally Posted by Doonz
(Post 18128643)
In the rare event your dealer gives grief about it, you'll have proof the FSA is assigned to your VIN if it is. |
Originally Posted by arkie3
(Post 18128562)
Released in April, and I just got mine last week, around August first. Mine is dated July 2018, but is code 18M01. And apparently you read it the same way I did - that even if odometer mileage is higher than 120,000, Ford will fix the problem through the end of this year. Is this a valid reading of what the letter says?
2013 6.7 f250
when referring to limp mode are we talking about reduced power or reduced speed? |
Not power but reduced speed. Mine was limited to 50 MPH then after that it may have gone to idle mode. It would appear that when the limit to 50 appears that if you dont shut off the truck that it will keep running normal. When you shutoff the truck and start it again then the limit will start
