Need Head Gasket for L6 221 engine +1000HP ??
Hello, sorry about my english, I have a 221 Falcon Engine Six Inline with turbo and more than 1000HP, I have problems with Head Gasket, any recomendation who can Make a Gasket for this kinf of engine? I Know best option is Oring, but I need to try whit a better head Gasket first. Any Maker? or custom made? Thanks a lot.
Have you tried dead soft copper?
https://fordsix.com/viewforum.php?f=1
https://fordsix.com/viewforum.php?f=22 Try posting your questions on those small block 6 Forums. |
NO, Im in south America, so I will try in USA, where do you tell me. Thanks
Thanks I will do it.
I dont understand what you say, google I google dead soft copper and I See what is that, Is for O ringing no? I need to machine the block to put it? Sorry about my english
If me and I had gaskets that keep blowing I would just go for O-ring the block and ARP head studs if you are not running studs.
I know some motors that run high compression you can drill the block and heads for more studs. Don't know if that can be done with your motor? Dave ---- |
Thanks a lot, Im runnig with big studs yes, Im lookin for someone who can make a customs MLS Gasket or similar, prior tu machine my block to put orings
If you have the budget to do it go Cometic. Cometic Gasket, Inc.
I believe they do custom gaskets but I doubt it will be cheap. |
