Looking for Intake Ducting
my 4.0 Aerostar intake duct is shot. The "accordion" section is cracked, I have sealed it temporarily.
the rubber gasket or seal has turned into chewing gum. the part number on the Duct is: F69E-9R504-AA I have no part numbers for the two rubber seals, which are different in size. If anyone can help get these parts new or used in perfect shape, please let me know. https://www.use.com/images/s_2/88dda782583991d33b5f.jpg https://www.use.com/images/clicklarge3.gif https://www.use.com/images/s_2/869e5933b39e083786a2.jpghttps://www.use.com/images/clicklarge3.gif |
Originally Posted by Jose A.
(Post 17783112)
the rubber gasket or seal has turned into chewing gum. the part :-huh number on the Duct is: F69E-9R504-AA F69Z-9B659-AA .. Engine Air Cleaner Tube / Marked: F69E-9R504-AA / Obsolete 1996/97 Aerostar 4.0L NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746. |
Thank you very much Bill. I already left them a message.
This will remind me to look for one the next time I'm in the scrap yard.
Mine on my 3.0 is crap also. I've got duck tape around it with large zipties, I would love to find one.
sittinguy, the 3.0 is easier to find, the problem is with the 4.0.
Bill, I called Gary at NOS Parts Source, he does not have one. Several junkyards have them but with worse damage than mine. |
I can't find a new one, I just tried again for an hour. BUT, I will send anyone a free NOS hood rod clip for your Aero :) If someone can help me find one :)
Originally Posted by sittinguy
(Post 17785435)
Thanks for tryin. I've even searched overseas a little. Nothing
F69Z9B659BA I think is the part # for the 3.0
(Post 17785727)
F69Z9B659BA is the part # for the 3.0
But, there was another number originally. 1992/97 Aerostar 3.0L I ran both of these part numbers, no one has any. |
used only if we're lucky.
Has to be a K&N kit that will fit......
Something like a Ranger or some other car?? Something with the proper diameter, turn, and length. And the 4 bolt mount on the filter to fit our Mass Air. Here's one that could work, maybe https://www.carid.com/knn/77-series-...vigation=sp157 |
I used a generic custom intake kit. Not recommended. It had a lot of problems.
But what you can do is have a muffler shop build one using exhaust tubing. You will want a flex section in it and use silicone clamp on sleeves on the ends. It will need a fitting added for the breather tube as well. |
mine has a Intake Air Temp sensor too.
