Water Pump Bolts
I have removed my water pump for replacement. Two of the bolts are seriously rusted about half way through. Where can I get a new set of bolts? The two I need have a bolt head about 1 1/2" down the shaft. The local NAPA store has no resources & I'm dead in the water. Any help/advice? Thanks.
I replaced mine with bolts from a local supplier. The bolt with the head part way down is probably a threaded stud with a nut on it. If you have the old bolts, it should be no problem to match them up. I used grade 8 instead of the grade 5 stock bolts. Just don't over torque them.
Thank you! I'm going to try the local (21 miles away) junkyard and if that doesn't work then I guess that Ace is the place!
https://lmr.com/item/LRS-8501AHDW/19...mp-Studs-Bolts
I wouldn't suggest going to the junk yard for these. Most of the time your going to snap them off while trying to extract them. If you do get them out, it's possible to snap them off while reinstalling them on your truck trying to get them to the proper torque. This is one of those deals where you don't want to skimp with old parts. |
I knew Dorman had the partial kit with just the studs, but without the bolts. I didn't know that LMR had a complete set. They sure are proud of them though.
Originally Posted by TexasGuy001
(Post 17727557)
High Quality Construction The water pump bolts, studs, & nuts are made from ARP 8740 chrome moly steel. They are nominally rated at a 180,000psi tensile strength - a fair margin sturdier than standard Grade 8 hardware & significantly stronger than the factory pieces. Plus, they are Black Oxide coated for corrosion resistance. |
Harder to drill out if they break. Using harder hardware is a mixed bag. Ford knows best.
Originally Posted by HardScrabble
(Post 17729102)
That "ford knows best" statement in my opinion only pertaines to Ford Design. However the materials and hardware is pretty much a compromise between quality and quantity to make the over all cost of the vehicle more cost effective. That being said its not out of the question to go out and find a better part quality wise. Not a better design, but a better part. Just my opinion. |
Engineers design a great product, then it goes in front of accounting to be cheapened then it goes to lowest bidder for construction
Bean counters are destroying the planet.
If a company built an indestructible product:
A) You ain't gonna' pay for it cause it'd cost too much... B) The company would go out of bid'ness cause they'd never sell enough. So there. |
Not so sure about that, at least with the younger generation anyway. They'd still trade it for something newer because if they don't have the latest and greatest they might get affended or their feelings hurt somehow :D
Originally Posted by Scndsin
(Post 17730589)
A) You ain't gonna' pay for it cause it'd cost too much... B) The company would go out of bid'ness cause they'd never sell enough. So there. I have a mid 80's Exmark mower that thing is built like a tank. Awesome product... |
