Water Pump Bolts - Ford Truck Enthusiasts Forums
Water Pump Bolts
Old 01-15-2018, 12:55 PM
BocceMon BocceMon is offline
BocceMon is starting off with a positive reputation.
Water Pump Bolts
I have removed my water pump for replacement. Two of the bolts are seriously rusted about half way through. Where can I get a new set of bolts? The two I need have a bolt head about 1 1/2" down the shaft. The local NAPA store has no resources & I'm dead in the water. Any help/advice? Thanks.
Old 01-15-2018, 02:06 PM
Pappawheely's Avatar
Pappawheely Pappawheely is offline
Pappawheely is gaining momentum as a positive member of FTE.Pappawheely is gaining momentum as a positive member of FTE.
I replaced mine with bolts from a local supplier. The bolt with the head part way down is probably a threaded stud with a nut on it. If you have the old bolts, it should be no problem to match them up. I used grade 8 instead of the grade 5 stock bolts. Just don't over torque them.
Old 01-15-2018, 02:11 PM
Thank you! I'm going to try the local (21 miles away) junkyard and if that doesn't work then I guess that Ace is the place!
Old 01-15-2018, 02:21 PM
Inside Man's Avatar
Inside Man Inside Man is offline
Inside Man is starting off with a positive reputation.
https://lmr.com/item/LRS-8501AHDW/19...mp-Studs-Bolts
I wouldn't suggest going to the junk yard for these. Most of the time your going to snap them off while trying to extract them. If you do get them out, it's possible to snap them off while reinstalling them on your truck trying to get them to the proper torque.
This is one of those deals where you don't want to skimp with old parts.
Old 01-15-2018, 04:02 PM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I knew Dorman had the partial kit with just the studs, but without the bolts. I didn't know that LMR had a complete set. They sure are proud of them though.
Old 01-15-2018, 06:48 PM
Scndsin's Avatar
Scndsin Scndsin is offline
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Old 01-15-2018, 11:20 PM
Inside Man's Avatar
Quote:
Thought the price was a little steep myself but after some thought these may not be a hastle to remove like the factory ones were after a long period of time.
High Quality Construction
The water pump bolts, studs, & nuts are made from ARP 8740 chrome moly steel. They are nominally rated at a 180,000psi tensile strength - a fair margin sturdier than standard Grade 8 hardware & significantly stronger than the factory pieces. Plus, they are Black Oxide coated for corrosion resistance.
Old 01-16-2018, 08:47 AM
HardScrabble HardScrabble is offline
HardScrabble is gaining momentum as a positive member of FTE.
Harder to drill out if they break. Using harder hardware is a mixed bag. Ford knows best.
Old 01-16-2018, 09:06 AM
Inside Man's Avatar
Quote:
It's possible but less likely.
That "ford knows best" statement in my opinion only pertaines to Ford Design. However the materials and hardware is pretty much a compromise between quality and quantity to make the over all cost of the vehicle more cost effective.
That being said its not out of the question to go out and find a better part quality wise. Not a better design, but a better part.
Just my opinion.
Old 01-16-2018, 05:03 PM
Workingstiff Workingstiff is offline
Workingstiff is starting off with a positive reputation.
Engineers design a great product, then it goes in front of accounting to be cheapened then it goes to lowest bidder for construction
Old 01-16-2018, 05:06 PM
Bean counters are destroying the planet.
Old 01-16-2018, 06:22 PM
Scndsin's Avatar
If a company built an indestructible product:
A) You ain't gonna' pay for it cause it'd cost too much...
B) The company would go out of bid'ness cause they'd never sell enough.
So there.
Old 01-16-2018, 09:06 PM
Inside Man's Avatar
Not so sure about that, at least with the younger generation anyway. They'd still trade it for something newer because if they don't have the latest and greatest they might get affended or their feelings hurt somehow
Old 01-19-2018, 08:37 PM
So there.
Not true, the only place I wish Ford would have put a few more cents into it are, rear wheel wells, rear spring shackles and hydraulic clutch cylinder. Oh and oil pan.
I have a mid 80's Exmark mower that thing is built like a tank. Awesome product...
Water Pump Bolts Discontinued? Jmudweiser 1999 - 2003 7.3L Power Stroke Diesel 8 12-21-2017 12:07 PM
Water Separator bolt broke inside.. 8LugFilmmaker 1999 to 2016 Super Duty 1 09-24-2017 06:14 AM
Fan to Water Pump Bolts acl9865 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-22-2017 03:00 PM
1952 Ford F1 215 Pulleys Artf0rm 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 02-11-2017 10:38 AM
Water pump mattnj Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-06-2016 09:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
