Transmission goes straight to 5th gear when cold - Won't shift to 1st gear when stopped
1 Attachment(s)
It's a 2017 F350 LWB with 3600 miles. Bought new in October 2017.
I use the remote start 98% of the time. When it's really, really cold I notice that sometimes when I put the gear selector in "D", I can't get the truck to move forward. Like the transmission is slipping. It's done this about 6 times this winter. I park on a sloped driveway and thought maybe the fluid was low. Then I was parked on level ground and pulled out of a parking lot up to an intersection to turn left. The transmission was slipping like it wasn't in "1st" gear. I put it in reverse and it goes backwards fine. I put it back in "D" and it still slipped. I decided to turn right with the traffic flow and the truck finally went in to 1st - and STAYED in first for two blocks. I pulled over in a parking lot and shut the truck off and restarted. Seems to have gone away for the moment. Yesterday, I started in the driveway and pulled out. mI had to really press the gas to get out of the driveway. I got out of the sloped driveway and rolled up to the stop sign at the end of my street. I looked a the gear indicator and it showed the truck was in "5th" gear. I turned the truck off and restarted and it went fine all day. Sometimes it will grab and give me a "chunk" like putting it in gear while revving the engine. Which is exactly what's happening. Here's a pic of the gear indicator in 5th gear while stopped at "0" mph. What do you folks think? I live in Chattanooga TN and the dealer I bought from is in Murfreesboro, TN about 130 miles away. Should i take it to a local dealer? https://cimg9.ibsrv.net/gimg/www.for...3f70be8a5e.jpg |
Absolutely take it to the local dealer. They will honor the warranty.
5th gear clutch packs, torque converter, and fluid are not going to like this...
Have you tried to manually shift with the + or - buttons? I agree with Clubwagon.
Agreed on the trip to a dealer. If you use M and shift with the "+ / -" can you make it go into first?
Originally Posted by stewy604
(Post 17727325)
I tried the manual shift yesterday and couldn't get it to change the gear selector on the dash. I stayed on 5th gear. I put it in park and then back to "D" and it was still in 5th according to the indicator on the dash. I pulled it down in to L and 2 and nothing changed on the dash. |
Yesterday was the first time I had noticed the indicator was showing it was in 5th gear while stopped. I'll call the dealer today and keep you posted on what they say.
5 th gear
I am having the same issue with my 2015. When cold the trans will go to 5th. Talked to the dealer and was told it is a safey feature to go to 5th and lock the converter so the trans won' slip. But today I let the trans warm up to 80 degrees and it still did it. Reverse works fine, drove it and finally started working correct at 140 degrees. Looks like another trip to the dealer, owned the truck 45 days and just had catalytic converters replaced.
I dropped it off at the dealer this morning at 9. It's 8:51 PM Eastern. Haven't heard from them today at all. I'm guessing it's something electrical or a sensor, since the problem corrects itself when I turn the ignition off and restart it. Glad I've got another vehicle to drive.
Originally Posted by Pintoman8
(Post 17730873)
Originally Posted by WarriorDog
(Post 17730904)
How many miles on it?
Diagnosis
Service tech tells me mine has a bad transmission pump seal.
(Post 17730873)
... When cold the trans will go to 5th. Talked to the dealer and was told it is a safey feature to go to 5th and lock the converter so the trans won' slip. ...
(Post 17730873)
Is this a 6.2 with the new trans? My truck is the 6.7 and has been drove in -2* temps and it does not lock in 5th gear and thats pretty cold in my book.
