Truck + Camper + Scale Weight Pictures
I'm going to keep this simple so maybe it will help others when looking at truck/trailer combos. Here is my combo along with CAT scale weight sheet. Please add more combos..........
2015 Ford F350 6.2L CCLB 4.30 gears 11,200# GVWR for truck (3674 lb payload by door sticker) 2018 Reflection by Grand Design 311 BHS Anderson Ultimate Hitch No cargo in 5th wheel as of this pic https://cimg3.ibsrv.net/gimg/www.for...73dbdae501.jpg https://cimg6.ibsrv.net/gimg/www.for...43ef8b8e6d.jpg |
I guess the round badge on the front door of truck..
is that the aftermarket 6.2L that looks like the 6.7 Diesel badge . does your truck have the upper limit of 6,100 pounds on the rear axle? a real good looking rig you have there. |
Originally Posted by Chuck's First Ford
(Post 17659551)
is that the aftermarket 6.2L that looks like the 6.7 Diesel badge . does your truck have the upper limit of 6,100 pounds on the rear axle? a real good looking rig you have there. Rear axle is 7000 lb according to decal on door. Front is 6000 lb. |
Originally Posted by CaptFX4
(Post 17659672)
Yes it is an aftermarket 6.2L badge. Just like the looks of it.
Nice looking rig, CaptFX4. I wish my Reflection 337 looked that clean and shiny - and I just washed it yesterday. (BTW - Andersen is spelled with an "e.")
Door sticker payloads don't mean much and the only way to know that true number is to weigh the truck without the trailer hitched up. However, your loaded numbers indicate you're well below the rear axle ratings of the truck, so you're fine. As full timers, we pull across the scales a couple of times a year - gotta keep that "weight creep" in check! Here are our numbers from last week. The rig is the rig in my signature. The trailer axle capacities (7K each) are different from stock because the trailer has the MOR/ryde independent suspension and disc brakes on it. I still stick to the trailer's 13,990 GVWR as rated, though. As you can see, I have ten pounds to go on that! https://cimg5.ibsrv.net/gimg/www.for...662c8024fd.jpg Happy camping! Rob |
2013 CCLB DRW 6.7 4x4 Curt GN to 5th rail adapter and Reese hitch Trailer tanks empty 2/3 tank of fuel 2018 Columbus Compass 377MBC https://cimg3.ibsrv.net/gimg/www.for...17557df903.jpghttps://cimg4.ibsrv.net/gimg/www.for...4af8e47087.jpg |
https://cimg9.ibsrv.net/gimg/www.for...ce644e829d.jpg
https://cimg0.ibsrv.net/gimg/www.for...438402ad76.jpg 40' winnebago scorpion 15k dry 2900 pin weight 2017 F350 srw camper pkg snow plow pkg I got to go digging for my scale paperwork I'll post back on here soon .hope this helps someone |
