Number Dummy, need part numbers for
A 65 F600 300 I6 frt motor mount. This is the rubber biscuits and sleeve. Reference #6068, Also who may have them. Thanks
Originally Posted by GJCAT
(Post 17630128)
GREEN SALES CO. in Cincinnati OH has 43 = 800-543-4959. -------------------------------------------------------------------- 1) C1TT-6A061-C .. Lower Front Insulator / Obsolete GREEN SALES CO. has 2. OBSOLETE RELIABLE PARTS in Nashville GA has 3 = 229-686-5101. ---------------------------------------------------------------------------- 1) C3TZ-6068-D .. Upper Front Insulator / Obsolete GREEN SALES CO. has 175. |
Bill one other number I need to find Reference #6068 rear mounts between the bell and the frame for the 65 truck 6 cylinder engine. Thanks
(Post 17634518)
Anchor makes them (and a number of others).. I get mine directly thru oriellys.. special order.. but they are cheap.. Ford also used them in other applications as well.. I believe you can get anchor from summit racing.. very cheap..Ive been trying to cross reference the part number by picture... There is an on-going thread from bill that is the parts thread https://www.ford-trucks.com/forums/1...y-info-44.html |
Thanks for the info. Is there a parts CD for these trucks?
(Post 17637076)
(Post 17634518)
Bill one other number I need to find Reference #6068 rear mounts between the bell and the frame for the 65 F600 300 I-6.
MILLER OBSOLETE PART in Binghamton NY has 4 = 607-722-5371. CARPENTER NOS OBSOLETE PARTS in Concord NC has 20 = 800-476-9653. GREEN SALES CO. in Cincinnati OH has 43 = 800-543-4959. -------------------------------------------------------------------- 2) C4TZ-6A061-A .. Lower Rear Insulator / Obsolete CARPENTER NOS OBSOLETE PARTS has 1. MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965. ----------------------------------------------------------------------------- 2) C5TZ-6068-E .. Upper Rear Insulator / Obsolete MILLER OBSOLETE PARTS has 1. 1964/72 Ford Truck Parts Catalog available on a C/D from hipoparts.com |
I have an email into anchor industries
I believe anchor ani-2048 and 2050 may be the same motor mounts (listed for earlier applications). I am asking them for the physical dimensions.. .. the above mounts are a couple of dollars through Summit.. here's hoping https://i.imgur.com/9wSivuY.jpg Follow up email from ANCHOR Industries Anchor said they dont list F600s specifically but said look at the above mount as well as this one https://i.imgur.com/L2i4rOx.jpg its slightly larger than the one above... ani-2014 The reason these are worth following up on is cost.. these are in the 3 dollar range.. all the NOS ones are three to four times and more of that price. Im going to order one of each..Ill update my results |
(Post 17630786)
1) C1TT-6A027-B .. Sleeve / Obsolete
GREEN SALES CO. in Cincinnati OH has 43 = 800-543-4959. -------------------------------------------------------------------- 1) C1TT-6A061-C .. Lower Front Insulator / Obsolete GREEN SALES CO. has 2. OBSOLETE RELIABLE PARTS in Nashville GA has 3 = 229-686-5101. ---------------------------------------------------------------------------- 1) C3TZ-6068-D .. Upper Front Insulator / Obsolete GREEN SALES CO. has 175. For example.. these guys https://www.steelerubber.com/motor-mount-20-0597-11 Thank you |
Originally Posted by Notmeofficer
(Post 17656805)
Bill.. when I run these number they pop up for a lot of other trucks other than F600s... including light duty.
if this is true :-X22 then these mounts are available potentially new.. but I'm still a little confused. Are these also spec'd for a bunch of light duty fords in the 60s?.. can you tell? Of course! For example.. these guys https://www.steelerubber.com/motor-mount-20-0597-11 Thank you I didn't list any of the applications, just listed the part numbers for the OP's application ('65 F600). Here's the pages from the 1957/63 truck catalog for 272/292 front & rear motor mounts. Do some of these part numbers look familiar? :-X04 https://cimg2.ibsrv.net/gimg/www.for...3899b9d7ef.jpg https://cimg4.ibsrv.net/gimg/www.for...bd1ed176e7.jpg |
(Post 17657142)
If I listed all the applications for these puppies, it would take me...at least...several hours.
I didn't list any of the applications, just listed the part numbers for the OP's application ('65 F600). Here's the pages from the 1957/63 truck catalog for 272/292 front & rear motor mounts. Do some of these part numbers look familiar? :-X04 https://cimg2.ibsrv.net/gimg/www.for...3899b9d7ef.jpg https://cimg4.ibsrv.net/gimg/www.for...bd1ed176e7.jpg But what you did provide was confirmation that the Anchor aftermarket ones 2048 and 2050 ARE CORRECT by application.. and as such Im ordering them.. this is a gold nugget find because they are new.. and cheap compared to green sales or carpenter.. Santa will be generous to you..as he should |
This info will get me the parts I need for the rear mounting. Many thanks to you both. we had several of these f 600 I6 trucks around yrs ago and a lot of them ended up in a local truck yard. The owner of the yard died about 5 yrs ago and as usual the yard got cleaned out. Tanks again.
(Post 17658564)
GJCAt I got the anchor motor mounts today... they are too small.. they would fit the light duty 300s... Im still searching |
Hello Number Dummy, Looking for the part number for the temp gauge in my 1970 C700.
Originally Posted by Randy wise
(Post 17810732)
