V10 60,000 mile. What to service???
Hi, Have 1999 32 ft RV with V10 that is coming up to 60,000 miles. I regularly have oil filter and airfilter changes. It has no problems but I feel at 60,000 it needs a service. Was thinking of the serpentine belt, coolant and transmission fluid change/flash. Interested in your opinions and suggestions. We are based in Dallas. Thanks
If you never had the coolant changed, defiantly good flush, should be done at least every 5 years.
Transmission fluid is also a good idea at that mileage. |
On every vehicle I have ever owned, every two years I change trans fluid & filter, differential/gear oil, coolant and brake fluid.
— Dave |
Do all fluids. Transmission, differential, brake, power steering, coolant.
Also change the fuel filter. Run the engine nice and hot before you park it for the winter. Keep a battery maintainer on it. Don't run the engine to idle it (no need), unless you idle it for a while to FULLY warm up engine and oil. All very easy to do. These rv engines suffer more from sitting than being used. With good maintenance they can last a long time. |
