V10 60,000 mile. What to service???
Hi, Have 1999 32 ft RV with V10 that is coming up to 60,000 miles. I regularly have oil filter and airfilter changes. It has no problems but I feel at 60,000 it needs a service. Was thinking of the serpentine belt, coolant and transmission fluid change/flash. Interested in your opinions and suggestions. We are based in Dallas. Thanks
Do all fluids. Transmission, differential, brake, power steering, coolant.
Also change the fuel filter.
Run the engine nice and hot before you park it for the winter. Keep a battery maintainer on it. Don't run the engine to idle it (no need), unless you idle it for a while to FULLY warm up engine and oil.
All very easy to do.
These rv engines suffer more from sitting than being used. With good maintenance they can last a long time.
