Need a Guess at Hitch Capacity
This trailer hitch is on a 1986 F-350 dually at the wrecking yard. It is well made and available for $35 if I pull it. The label is long gone so I don't know what the towing rating is.
I am hoping someone recognizes it and can tell me the towing capacity is. Thank You https://cimg2.ibsrv.net/gimg/www.for...6ea82d452c.jpghttps://cimg3.ibsrv.net/gimg/www.for...4484add906.jpg |
Class IV rating, typically 10K
Thanks. 10,000 is what I was hoping to hear. Hopefully the forklift guy re-positioned the supports like he said he would so I can remove it.
Given that it was on a dually I would expect it to be a decent hitch.
I would get new bolts/washers and nuts for it, grade 8. |
Originally Posted by senix
(Post 17511968)
I would get new bolts/washers and nuts for it, grade 8. I like the extra thick grade 8 washers. Would you recommend lock washers, nylock nuts or thread locker. |
lock washers and thread locker.
I would torque them down, wait a week and re-torque again. I believe the hitch to be a reese. Max tongue weight is gonna be 1K. 80 Ft lbs on all bolts. |
(Post 17512482)
Originally Posted by HRTKD
(Post 17512588)
Wouldn't that break the thread locker?
You know you are right! Delete the re-torque advice. |
(Post 17512588)
Shouldn't move at all. |
Originally Posted by Cummings Guy
(Post 17512708)
(Post 17513932)
Red locker for sure. Blue? I bet it would release.
My new Torklift SuperHitch 20K that has a 2000lb tongue weight rating used Grade 8 hardware with lock washers and standard nuts that were torqued to 80 ft/lbs. |
Wouldn't mind finding a Torklift SuperHitch in the wrecking yard.
This is what is left of the label. I bet somebody recognizes the trace of the logo. https://cimg9.ibsrv.net/gimg/www.for...aa9f2b0843.jpg Logo on yard find tow hitch. |
As long as everything is new and or very clean blue will work just fine. I rarely ever use red anymore, unless I Absolutely Positively don't want to take it back off. Ditto on the no retorque when using locktight.
Sticker, what's left of it looks like a U-Haul. I use grade 8 bolts and washers on all my hitches and grade 8 self locking nuts, no LockTite and check torque every year.
Originally Posted by WE3ZS
(Post 17514529)
The factory used blue thread locker on the Excursion hitch bolts for sure, probably the same on the SD pickups.
My new Torklift SuperHitch 20K that has a 2000lb tongue weight rating used Grade 8 hardware with lock washers and standard nuts that were torqued to 80 ft/lbs. First off, what a BEAUTIFUL EX! In a 'previous life' I had a '05 EB EX, 4X4 6.0 PSD as a company truck...man, I loved that truck! All, I'm in agreement for clean, yellow zinc plating/coated, Grade 8 bolts with a Grade 8 flat washer,one at bolt head and one at nut end, with Grade 8 spring-lock or split-locking washers and standard nuts. Blue thread locker is optional, but not required. Red loctite may require heat to remove. To assist in the corrosion-resistance, twice a year I use a hand sprayer to dampen the hitch connectors with diesel oil (fuel oil); to keep the rust to a minimum..... It works for me - 'your mileage may vary'. BarnieTrk :-X0A6 |
