Need a Guess at Hitch Capacity - Ford Truck Enthusiasts Forums
Old 10-07-2017, 07:05 AM
Cummings Guy Cummings Guy is offline
Cummings Guy is starting off with a positive reputation.
This trailer hitch is on a 1986 F-350 dually at the wrecking yard. It is well made and available for $35 if I pull it. The label is long gone so I don't know what the towing rating is.
I am hoping someone recognizes it and can tell me the towing capacity is.
Thank You
Old 10-07-2017, 06:53 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Class IV rating, typically 10K
Old 10-07-2017, 08:33 PM
Thanks. 10,000 is what I was hoping to hear. Hopefully the forklift guy re-positioned the supports like he said he would so I can remove it.
Old 10-07-2017, 08:36 PM
senix's Avatar
Given that it was on a dually I would expect it to be a decent hitch.
I would get new bolts/washers and nuts for it, grade 8.
Old 10-07-2017, 09:24 PM
I would make the same assumption too.
I like the extra thick grade 8 washers.
Would you recommend lock washers, nylock nuts or thread locker.
Old 10-08-2017, 07:04 AM
senix's Avatar
lock washers and thread locker.
I would torque them down, wait a week and re-torque again.
I believe the hitch to be a reese. Max tongue weight is gonna be 1K.
80 Ft lbs on all bolts.
Old 10-08-2017, 08:38 AM
HRTKD's Avatar
HRTKD HRTKD is offline
HRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to behold
Wouldn't that break the thread locker?
Old 10-08-2017, 08:46 AM
senix's Avatar
Quote:
You know you are right! Delete the re-torque advice.
Old 10-08-2017, 09:33 AM
Shouldn't move at all.
Old 10-08-2017, 09:01 PM
HRTKD's Avatar
Quote:
Red locker for sure. Blue? I bet it would release.
Old 10-09-2017, 08:00 AM
WE3ZS's Avatar
WE3ZS WE3ZS is offline
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
The factory used blue thread locker on the Excursion hitch bolts for sure, probably the same on the SD pickups.
My new Torklift SuperHitch 20K that has a 2000lb tongue weight rating used Grade 8 hardware with lock washers and standard nuts that were torqued to 80 ft/lbs.
Old 10-09-2017, 11:40 AM
Wouldn't mind finding a Torklift SuperHitch in the wrecking yard.
This is what is left of the label. I bet somebody recognizes the trace of the logo.
Logo on yard find tow hitch.
Old 10-11-2017, 04:42 PM
TJReams's Avatar
TJReams TJReams is offline
TJReams has a good reputation on FTE.TJReams has a good reputation on FTE.
As long as everything is new and or very clean blue will work just fine. I rarely ever use red anymore, unless I Absolutely Positively don't want to take it back off. Ditto on the no retorque when using locktight.
Old 10-11-2017, 11:04 PM
jetjockey99 jetjockey99 is offline
jetjockey99 is gaining momentum as a positive member of FTE.
Sticker, what's left of it looks like a U-Haul. I use grade 8 bolts and washers on all my hitches and grade 8 self locking nuts, no LockTite and check torque every year.
Random Questions (hoses/brakes/clutch) sere0501 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-14-2017 09:14 PM
Anti Rattle & Vent Window install sere0501 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-23-2017 07:45 PM
The Apocalypse build thread... "Bad Horse" Apocalypse Excursion - King of SUVs 424 12-19-2016 09:00 AM
winter time shrtmem Excursion - King of SUVs 6 11-08-2016 06:39 AM
2000 F-350 7.3 jackfordsd350 Vehicles for Sale 2 10-12-2016 03:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
