How to disable 2002 Ranger DRLs
My 2002 X-cab 4x4 4.0 SOHC has been flawless so far, but I HATE the daytime running lights, how the h*** can I disable them, fuses and relays named to them also run other items...........Ideas?
Why do you hate DRL?
All you have to do is remove the DRL module and replace it with a bypass(non DRL) module, this jumpers a couple circuits so the headlights and dash indicators still work. The module is located on the rad support near the drivers side headlight. |
Originally Posted by Conanski
(Post 17321433)
All you have to do is remove the DRL module and replace it with a bypass(non DRL) module, this jumpers a couple circuits so the headlights and dash indicators still work. The module is located on the rad support near the drivers side headlight. I also would like to be able to creep along logging roads in early morn/late evenings scouting before hunting season without having these things broadcast my presence. Thanks for the useful info on the module! where do you find a bypass module? |
I don't have diagrams for yours, but when a friend asked me to do this on his Hyundai i looked at his diagram and snipped the ignition sense wire at the DRL module. DRL's wont work if the module thinks the engine isn't running. Take a look at the diagram and see if this will work on yours.
Or you might be able to remove the wire from the E-Brake and ground it, |
Originally Posted by Old93junk
(Post 17322003)
I do not like the batt. drain and loss of lamp-life this pretty much useless "safety option" entails, if I want my headlights on during the day I will turn them on, I don't need another gov. mandated, nanny-state function to "help" me.
I also would like to be able to creep along logging roads in early morn/late evenings scouting before hunting season without having these things broadcast my presence. |
