Speed cable
Hello, salutations from Spain. I recently acquired a transmission for my f100 of 56. It is the one you see in the picture I think it is 63 or 64 three speeds synchronized. I have to buy the pinion and the cable of the speedometer but I do not know what it is. some help? Thank you
https://cimg8.ibsrv.net/gimg/www.for...189aa1c1da.jpg https://cimg4.ibsrv.net/gimg/www.for...02db5d56b2.jpg https://cimg4.ibsrv.net/gimg/www.for...d98ec95fca.jpg |
Originally Posted by capelo
(Post 17296496)
Hello, salutations from Spain. I recently acquired a transmission for my f100 of 56. It is the one you see in the picture I think it is 63 or 64 three speeds synchronized. I have to buy the pinion :-huh and the cable of the speedometer but I do not know what it is.
1963/79 Ford/Merc Passenger Cars; 1963/86 F100/250; 1965/87 E100/250; 1966/77 Bronco. What is this pinion you're asking about? |
(Post 17296902)
Ford type 3.03 3 speed manual all syncromesh trans introduced in 1963.
1963/79 Ford/Merc Passenger Cars; 1963/86 F100/250; 1965/87 E100/250; 1966/77 Bronco. What is this pinion you're asking about? https://cimg5.ibsrv.net/gimg/www.for...addc462c00.jpg |
(Post 17297948)
I was referring to the speedometer Drive n gear (17271) and the cable. (17262)
https://cimg5.ibsrv.net/gimg/www.for...addc462c00.jpg Trans is the Ford 3.03 3 speed, what is the rear axle ratio and tire size? |
(Post 17298324)
Speedometer DRIVE (on the output shaft) & DRIVEN (at the end of the cable) gears: Rear axle ratio, tire size and transmission type must be known to get the correct parts.
Trans is the Ford 3.03 3 speed, what is the rear axle ratio and tire size? Tire size 28.89" |
1948-1979 V8 Ford Truck Manual Transmission Parts Manual Transmissions - Macs Auto Parts
I'm looking on this page but I do not know what's right |
The formula for caluculating the driven gear number of teeth on the speedo cable is as such
# DRIVE TEETH x AXLE RATIO x TIRE REV. PER MI. _____________________________________________ = # DRIVEN TEETH 1001 To calculate tire revs per mile 20168 _______________________________ = REVIOLUTIONS PER MILE TIRE DIAMETER (in inches) The yellow drive gear is 7 teeth if I remember correctly and it appears to have 7 teeth in your pic. ND will correct me if I'm wrong. So with that We know the tire diameter is 28.89" So 20168 / 28.89= 698.096 And round to 698 Revs per mile. Knowing that we can use the other formula 7 x 3.92 x 698 / 1001 = 19.13 and to round it to 19 So you need a driven gear with 19 teeth. This is the one you need. Ford - Ford Pickup Truck Speedometer Driven Gear - 19 Teeth - Plastic | B5A-17322-C - Macs Auto Parts Hope that helps |
Originally Posted by matthewq4b
(Post 17305732)
# DRIVE TEETH x AXLE RATIO x TIRE REV. PER MI. _____________________________________________ = # DRIVEN TEETH 1001 To calculate tire revs per mile 20168 _______________________________ = REVIOLUTIONS PER MILE TIRE DIAMETER (in inches) The yellow drive gear is 7 teeth if I remember correctly and it appears to have 7 teeth in your pic. ND will correct me if I'm wrong. So with that We know the tire diameter is 28.89" So 20168 / 28.89= 698.096 And round to 698 Revs per mile. Knowing that we can use the other formula 7 x 3.92 x 698 / 1001 = 19.13 and to round it to 19 So you need a driven gear with 19 teeth. This is the one you need. Ford - Ford Pickup Truck Speedometer Driven Gear - 19 Teeth - Plastic | B5A-17322-C - Macs Auto Parts Hope that helps Thank you very much for that information but that piece is like the one that now mounts my transmission of 56 and the box that I am going to mount is the one of 63. I think they are different gears and that is one of my doubts. I also have to buy the cable and I do not know which is correct. A little more help? Thank you |
(Post 17307044)
The Drive gear Is white 6 teeth.
Thank you very much for that information but that piece is like the one that now mounts my transmission of 56 and the box that I am going to mount is the one of 63. I think they are different gears and that is one of my doubts. I also have to buy the cable and I do not know which is correct. A little more help? Thank you I'll ND help out with the Speedo Cable, section 170 in the parts book just gives me a headache and I'll likely get it wrong anyway. Matthew |
Thanks for the help. I'm looking at these parts, they transmisión
http://www.macsautoparts.com/store/ford-pickup-truck-speedometer-driven-gear-19-teeth-pink-or-natural-type-2a-3-speed-manual-or-automatic-genuine-ford.html http://www.macsautoparts.com/store/ford-pickup-truck-speedometer-cable-assembly-manual-or-automatic-transmission.html |
1956 F100 with 3 M/T: Speedo cable is: 69.77" long.
1963/64 F100 2WD with 3 M/T all syncromesh trans: Speedo cable (C3TZ-17260-BY) is: 60.00" long. 1965/66 F100 2WD with 3 M/T all syncromesh trans: Speedo cable (C5TZ-17260-N) is: 64.80" long. |
(Post 17315827)
(Post 17318630)
Thank you very much for the clarification. I think the C5TZ-17260-N can serve. And which speedometer driven gear? CODZ-17271-B or C4DZ-17271-A. THANK YOU
(Post 17318733)
The formula for calculating the drive gear was posted that is all you need to figure it out.
(Post 17319612)
I already know that it is 19 teeth. But I see two A and another B. what is the difference? Thank you
