D50 ttb upper ball joint
Hello, I did a search looking for this topic on this forum and axles and such. I thought i would check with you all you good people before i tear up something.
https://cimg0.ibsrv.net/gimg/www.for...6bb226ef19.jpg Top ball joint https://cimg7.ibsrv.net/gimg/www.for...90c8f0ab62.jpg Top ball joint I am not sure about that piece with the split between the ball joint and the housing? How do i remove it? I bought a ball joint press and have put quite a bit of pressure on it nut no luck. https://cimg6.ibsrv.net/gimg/www.for...c91909b871.jpg Top ball joint underneath But after the pictures of the replacement upper ball joint i wounder if theres a retaing ring i am unaware of. The bottom ball joint is almost freeded. |
The piece you are looking at is the camber adjustment bushing.
When you go to get the truck aligned they may need to change it. |
If you are trying to change the balljoint, you need to get the lower balljoint loose and take the whole knuckle off the truck. You can then use a balljoint press and press the balljoint out of the knuckle.
Originally Posted by ArdWrknTrk
(Post 17110442)
(Post 17110499)
Take a pickle fork or chisel and drive inbetween the axle housing and the knuckle to put pressure on it. Keep driving, if it doesn't pop leave pressure on it, put your large nut back on it upside down, screw the nut down till it's a little bit above the threads of the upper balljoint and smack it with a hammer while you have the pickle fork putting pressure on it.
https://cimg6.ibsrv.net/gimg/www.for...c91909b871.jpg Put your pickle fork in that crack where you see oil and grease in the picture and drive it in there to spread it out and force it down. |
(Post 17111171)
D50 upper ball joint
Got a chance to put a pickle fork to it with no luck. Even combined with a press at the same time. Next day off i will put the press to it and crank until some gives. I took some pictures. For prosperity.
https://cimg8.ibsrv.net/gimg/www.for...0ec09d3a71.jpg C clamp and a pickle fork https://cimg5.ibsrv.net/gimg/www.for...95bbd2ba01.jpg Pickle fork c clamp press I also tried map gass. No luck yet. Keep you good people posted. |
Well managed to hammer the lower ball joint out from the bottom of the knuckle separating the knuckle from the yoke. Woo hoo!! Also removed the upper ball joint cup but not the upper ball joint ball and stud. I have pressed, heated, waxxed (using the hot parifan to penetrate), beaten, cussed and hollared. Yet that upper ball joint seems to be virtually welded to the yoke!?!
https://cimg2.ibsrv.net/gimg/www.for...832be06d32.jpg Well managed to rip the ball from the socket. Pictured is the beam upside down. The upper ball joint wont budge. At this point i am considering cutting the upper ball joint stud drilling the center and with a little home made thermite burning it from the housing. Just kidding with the thermite. Too hard to control. I will figure it out. |
More heat and/or a 20T press should take care of it.
Have you tried tightening the press/clamp and then smacking the *side* of the yoke housing with a big hammer?
Right adjacent to where you've put the big gouge in the ball joint in your last photo. They will usually pop right out. It really doesn't look so bad that it should be a problem, but I guess you never know. |
CountryBumkin thats something i hadn't even considered. May have to see what the local shop would charge me. Thanks.
Originally Posted by CountryBumkin
(Post 17128591)
Hi Jim, Yes i did try what you have mentioned. I am wondering if the adjustment sleave is causing the issue. Going to give it another crack at it after work.
(Post 17128609)
Originally Posted by bullnose1985
(Post 17128576)
[B][FONT="Georgia"][SIZE="4"]
https://cimg2.ibsrv.net/gimg/www.for...832be06d32.jpg Well managed to rip the ball from the socket. Pictured is the beam upside down. The upper ball joint wont budge. . |
(Post 17129929)
I hope I didn't steer you wrong with the pickle fork, but I think I did. That is what pulled the joint off the ball correct? I can see the marks in the picture. The large black cup on your press sits around that raised area in the picture and not on top of it correct? I think that raised area that is buggered up around the ball is what comes out of the knuckle.
