Building high idle switch for '97 7.3
Hello, new to FTE, but I did come across an old post here talking about high idle switches and it got me on the path but now I'm not so sure.
Link to old post I'm referencing: https://www.ford-trucks.com/forums/706681-high-idle-3.html https://cimg0.ibsrv.net/gimg/www.for...b92a8fbf6c.jpg I have my rheostat up to 5k ohms, wire, and an on/off switch. Do I just splice in the tan and brown wires they were talking about and run my rheostat up to the dash, and then do the same with the IVS? |
I honestly have no idea what you're talking about, but you can buy a tuner with a high idle built in and it'll plug right in.
Gahd dang, that's a lot of work when you can get a new TPS Chips for $160. After all of the problems I had with the TPS and IVS on my last truck, I wouldn't touch them if they aren't broke! LOL
Originally Posted by BBslider001
(Post 16806501)
Factory unit for what?
Hmmmm, never seen that one before. Looks complicated LOL...for PTO operation?
Not to complicated, it plugs in under the dash, near the data port. With a manual tranny it will come on when the E-brake is applied. Works good if you are jump starting equipment. You can also adjust the engine run speed with the buttons. Mine runs at around 1K with the E-brake set, depending on the battery charge. If the battery charge is a little low and the glow plugs are still on at first start up, it will kick the rpms up to around 1200, then when the battery charge is recovered or the GPS kick off it will drop the rpms back to 1K.
(Post 16810063)
lol Byron saw a shiny thing and needs it.
Originally Posted by Shawn MacAnanny
I see a compete kit on ebay for $300, how big is this unit? Does it actually fit into the dash anywhere? I assume when the transmission is placed in park in an auto is when it would use the high idle setting?
(Post 16810977)
Dang Tom, now you are making me want one. LOL Where did you get yours?
