Strange water leak
2 Attachment(s)
Has anyone ever seen something like this happen to a plastic fitting, this was in the water inlet to my water heater with a plastic pex fitting attracted to it.
Denny |
It looks like the one side either wore away from friction or melted a bit. I have not seen this before.
There was no sighs of any pieces in the pex fitting and I didn't notice a leak until yesterday but it has been leaking for a few days, one good thing is we are in the desert so everything is drying put fast.
Denny |
Haven't seen it before. The only thing I just now at the tank are brass back check valves. If the internals are not necessary because of shut offs on the pex, I gut them.
Steve |
My tank is steel with no brass fittings anywhere and the end that is bad went into the plastic pex fitting. When I get to Yuma and have time I'm going to change the top fitting, I want to do it the morning and not late on a Saturday afternoon in case I run into problems.
Denny |
Denny,
I just always replace anything screwed into the tank with brass. I have had problem with those little plastic nipples leaking, so I just don't mess with them. Steve |
Originally Posted by RV_Tech
(Post 16718851)
Denny,
I just always replace anything screwed into the tank with brass. I have had problem with those little plastic nipples leaking, so I just don't mess with them. Steve Denny |
makes me wonder if checking this area is something to add to the checks?
I always, every few days, open the basement and take visual at the water connections but not the access area for the heater. |
Usually the leaks I see there are more common on units with considerable age and it depends on what has been used at the tank. I have the most trouble with that nipple that Denny included in his post. Even when I am installing a new one, sometimes I just can't get them to seal, so I just stopped using them at all. :)
Steve |
Originally Posted by senix
(Post 16720102)
I always, every few days, open the basement and take visual at the water connections but not the access area for the heater. Denny |
