are these good compression readings?
Just ran a dry compression test after warming up the engine (trying to troubleshoot why it idles a little rough)
1990 F350 7.5L (460) FI Are these considered good readings? Cylinder 1: 140 2: 139 3: 140 4: 139 5: 140 6: 145 7: 145 8: 150 |
Those all look good to me. You can check the rings by putting a small amount of oil in each cylinder through the spark plug and recheck compression. If it shoots up the rings are worn.
You are well within the 10% variance that is considered good and those numbers are pretty decent for a stock engine.
As it turns out the problem wasn't the engine misfiring causing the vibration, it was the fan clutch that had gone out and the fan was vibrating heavily because it was not centered anymore due to the clutch being messed up. Picked up a new fan clutch from Autozone for $35 and the problem is solved. Runs perfect.
Originally Posted by Christopher Layton
(Post 16202267)
Originally Posted by justcruzin125
(Post 16204689)
How many miles are on your truck?
