94 f-350 crew cab charging problems
I just did a 3g alternator conversion on this truck today, and it didnt work. I have done all the research I could find and to the best of my knowledge it should have worked. I took the alternator back and had it tested, and it tested good. So seeing if anyone that has done this can tell me if I did something wrong. I have the regulator hooked as this
A- yellow wire to battery S- to the single wire connector I- hooked to grn/red wire on truck Output- hooked to battery side of solinoid with 150A fuse I did remove old alternator harness because couldn't see a reason to leave it. Any help would be appreciated. |
Does your alternator/charge light come on?
Originally Posted by Lead Head
(Post 16047151)
It sounds like everything is wired correctly, I would check all your connections and make sure you don't have a wire broken somewhere, Do you have power to the green/red wire when the vehicle is running??
Originally Posted by vtjvt
(Post 16047256)
If there is power there I would test the wires and make sure you have continuity through them and the fuse
(Post 16047322)
Is there any reason to leave the factory wiring? |
The 150 amp fuse, I got rid of the factory wiring on my F250, and my Bronco.
If the alternator light does not come on when you turn the key on and the engine is off, either the bulb is burnt out, the alternator regulator is dead, or there is a wiring fault between the bulb and the alternator.
OK then I will try these things out and try again when I get home from work.
Wouldnt a 94 have a 3g from the factory?
Originally Posted by bashby
(Post 16048301)
I don't think the trucks switched over until '95 or 96. I have a bricknose so I'm not sure but my charge failure light has a resistor across the bulbholder (so the truck will charge even if the bulb burns out) |
(Post 16048301)
My 92 7.3 is factory 3g I believe.
The 7.3 may have had a different starting year than the 460.
