94 f-350 crew cab charging problems
Old 02-15-2016, 07:03 PM
van o
van o is offline
van o is gaining momentum as a positive member of FTE.
I just did a 3g alternator conversion on this truck today, and it didnt work. I have done all the research I could find and to the best of my knowledge it should have worked. I took the alternator back and had it tested, and it tested good. So seeing if anyone that has done this can tell me if I did something wrong. I have the regulator hooked as this
A- yellow wire to battery
S- to the single wire connector
I- hooked to grn/red wire on truck
Output- hooked to battery side of solinoid with 150A fuse
I did remove old alternator harness because couldn't see a reason to leave it.
Any help would be appreciated.
Old 02-15-2016, 08:14 PM
Lead Head
Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Does your alternator/charge light come on?
Old 02-15-2016, 08:32 PM
van o
van o is offline
No it doesnt. Had a meter on it and was losing voltage as it was running
Old 02-15-2016, 08:40 PM
vtjvt's Avatar
vtjvt
vtjvt is offline
vtjvt is starting off with a positive reputation.
It sounds like everything is wired correctly, I would check all your connections and make sure you don't have a wire broken somewhere, Do you have power to the green/red wire when the vehicle is running??
Old 02-15-2016, 08:54 PM
van o
van o is offline
I will have to check that. I would say that I do because I put the old alt. back in and it is working (kind of).
Old 02-15-2016, 08:59 PM
vtjvt's Avatar
vtjvt
vtjvt is offline
If there is power there I would test the wires and make sure you have continuity through them and the fuse
Old 02-15-2016, 09:08 PM
van o
van o is offline
Which fuse?
Is there any reason to leave the factory wiring?
Old 02-15-2016, 09:50 PM
vtjvt's Avatar
vtjvt
vtjvt is offline
The 150 amp fuse, I got rid of the factory wiring on my F250, and my Bronco.
Old 02-15-2016, 11:39 PM
Lead Head
If the alternator light does not come on when you turn the key on and the engine is off, either the bulb is burnt out, the alternator regulator is dead, or there is a wiring fault between the bulb and the alternator.
Old 02-16-2016, 04:35 AM
van o
van o is offline
OK then I will try these things out and try again when I get home from work.
Old 02-16-2016, 08:48 AM
bashby's Avatar
bashby
bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Wouldnt a 94 have a 3g from the factory?
Old 02-16-2016, 10:14 AM
ArdWrknTrk
ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Not really.
I don't think the trucks switched over until '95 or 96.
I have a bricknose so I'm not sure but my charge failure light has a resistor across the bulbholder (so the truck will charge even if the bulb burns out)
Old 02-16-2016, 10:40 AM
van o
van o is offline
I know that mine don't a friend of mine has a 95 and his is a factory 3g
Old 02-16-2016, 10:48 AM
bashby's Avatar
bashby
bashby is offline
My 92 7.3 is factory 3g I believe.
Old 02-16-2016, 11:31 AM
van o
van o is offline
The 7.3 may have had a different starting year than the 460.
Quick Reply: 94 f-350 crew cab charging problems
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
