Ford 226 Ground strap location cab to Bell housing?
Hi Guys,
I know this has been covered before but I cannot locate the thread, spent last 45 minutes looking for it. Where is the original location for the ground strap located at the back of the engine???? Original location for a 49 Ford with 226 H. How long is this strap?? Thanks in advance! |
This strap is an original and is exactly 15" end to end.
https://cimg7.ibsrv.net/gimg/www.for...ae21b4165.jpeg |
The attachment point is on the head. My battery posts were reversed making the cable too short.
https://cimg1.ibsrv.net/gimg/www.for...43ce92840b.jpg |
Thanks for all the pics.
Is there a ground strap that is located at the back of the engine that goes to the cab or frame? |
I haven't seen one on any 226 f1 that I have looked at personally and the 6cyl wiring diagram doesn't show one.
Jonathan |
The parts book lists 8rc-303-b engine to ground 8 1/4 long but it's only on the v8's.
Ok Great!
That answers my question. I always thought that the 226 also came stock with a ground strap at the back of the block. Thank you! |
Hey guys my ground strap is 15 1/2 inches long, but won't reach the back of the block, am I missing something? When removed a few years ago it was attached at the coil bracket which I understand is incorrect...?!?
http://i1346.photobucket.com/albums/...scqlwxsjq.jpeg |
As I found, the physical locations for the battery posts has been reversed over time. This puts the postive terminal away from the firewall and too long a reach for the stock cable. The alternatives were to find a battery with the legacy post configuration - I'm sure they could be found - or get a longer cable for the positive terminal to head connection. I opted for the longer cable.
Originally Posted by Vegas123
(Post 15892687)
Hi Guys,
I know this has been covered before but I cannot locate the thread, spent last 45 minutes looking for it. Where is the original location for the ground strap located at the back of the engine???? Original location for a 49 Ford with 226 H. How long is this strap?? Thanks in advance! https://www.ford-trucks.com/forums/1...und-strap.html |
Originally Posted by FortyNiner
(Post 16113689)
Originally Posted by ct50f1
(Post 16115754)
Thanks guys!! |
