5w20 or 0w20?
Anyone use 0w20 in their 6.2?, my wifes 2015 CRV calls for it and my previous Subaru did also. I just bought 2 Purolator Pure one filters and thinking of oils now
I would use what the Ford recommends.. 5w20.. If you were located up in the northern reaches of Alaska, then maybe 0w20... also see:
https://www.ford-trucks.com/forums/1...-new-6-2l.html |
Ford recommends 5W20 no need to over think it. The only decision might be to go full synthetic.
I always use Mobil1 5W-20..No need for 0W-20 where I live.
Full synthetic Mobil1 5W-20 for 12 years now. Nothing better.
I just switched over to full synthetic after swearing it off for years because everything I used it in had sprung a leak. It sure makes a difference , truck runs smoother and runs better with less effort. I would hesitate to go as far as more power but it does feel that way.
I just changed the oil for the first time and used 5w-30 Pennzoil Platinum. Which is a full synthetic. I put on a Mobil One extended use filter.
Originally Posted by R Guest
(Post 15805672)
Why did you go with a heavier oil - in a brand new motor, just in time for winter? |
Originally Posted by RightWingNutJob
(Post 15806176)
(Post 15806243)
5w-30 is the oil my 2016 truck calls for. I was reading the posts before I changed my oil and saw everyone was using 5w-20 and was surprised when I found my onwners manual and the oil fill cap said to use 5w-30. I triple checked. As I found it odd that they changed it. What are the other 2016 owners finding their trucks require?
