Help needed to decode F600 warranty plate
1 Attachment(s)
I found a Ford 600 with 86,572 original miles that I can pick up for $0.00 Can anyone help decode the info on the warranty placard? I've searched everywhere I could find with no luck, every place I found shows the warranty numbers starting with a "F" and the other descriptions for trans, axle etc don't match, any help is appreciated ��
It reads N60DVU88278 https://cimg4.ibsrv.net/gimg/www.for...42fa90579.jpeg |
I can tell you you do not have an F600, you have an N600.
16000 GVWR. Stand by...... |
Originally Posted by 85e150six4mtod
(Post 15735935)
You posted a nice clear pic, but it sometimes takes a day or more for Numberdummy or one of the other members with the decoder ring to see the thread.
I have a 1973 Shop manual, with all the codes for the 1973 model year.
I can get you PART of the way on a decode..................... N60DVU88278 N60 = N600 D= 330-2V, HD V8, Gas V = Kentucky Truck Plant U88278 = Calendar year month of production and sequential serial number (very likely 1974 or 1975). More: W.B. (wheelbase) = 202" Model N604 = ? Body 118 = ? Trans A = New Process 435 4-speed. Axle F2L: F2 = Eaton Model 15201 (15,000 Lb.) 2-speed, 5.83/8.12 Ratios. L = 6,000 Lb. power steering. GVWR = Fairly Obvious. D.S.O. 482401: District Sales Office that originally ordered the truck. 48 = Detroit, 2401 = sequential order number, most likely. Hopefully this will get you by for now. Keep in mind, any or all of this is subject to verification and/or correction (and I'm sure it will be ;)). |
Originally Posted by FBNengr
(Post 15748263)
(Post 15748263)
I can get you PART of the way on a decode... N60DVU88278 N60 = N600 :-huh D= 330-2V, HD V8, Gas V = Kentucky Truck Plant U88278 = Calendar year month of production and sequential serial number (very likely 1974 or 1975). W.B. (wheelbase) = 202" Model N604 = ? Body 118 = ? Trans A = New Process 435 4-speed. Axle F2L: F2 = Eaton Model 15201 (15,000 Lb.) 2-speed, 5.83/8.12 Ratios / L = 6,000 Lb. power steering. GVWR = Fairly Obvious. :-huh D.S.O. 482401 N60 = LN600 (gas). D = 330 2V Heavy Duty FT Engine. V = Kentucky Truck Assembly Plant. U88278 = 1974. 202" Wheelbase. COLOR: Blank. N604 = LN600 (gas); 16,000 lbs. GVWR 118: 11 = Medium Gray Vinyl / 8 = Standard Cab without Butterfly Hood. A = New Process 435 4 Speed Manual Transmission. F2L: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. Rear Axle Capacity. L = Ford 6,000 lbs. Capacity Front Axle with Power Steering. 16,000 lbs. Gross Vehicle Weight Rating. 482401: 48 = Detroit MI Ford District Sales Office, where the original selling dealer ordered thje truck from. 2401 = Domestic Special Order number. Truck painted a non standard color per the original purchasers order. N Series: 1963/69. |
1978 N600
n61dvcc7679
How about this one? i just bought this truck and any info would be great!! |
Welcome to FTE. See the picture in post 1. That is the data/warranty plate. In addition to the VIN, it has the trans and axle codes. See if you can post that info as well.
Sorry I can't post a picture yet the truck is still 120 miles away in Amarillo.
The main thing i was needing is the fact that it says N61. The 1 is the part i was wondering about. Also I wanted to share the fact that its a 1978 N600 series. I thought NumberDummy might like that. |
Originally Posted by mcmort
(Post 15810131)
The main thing i was needing is the fact that it says N61. The 1 is the part i was wondering about. Also I wanted to share the fact that its a 1978 N600 series. I thought NumberDummy might like that. N60 vs. N61--this question came up recently with respect to some F600 "model" numbers as seen in a parts page ND posted. The poster insisted he had what must be a "rare" F610. The explanation given is that the "F61" designation, vs. "F60" had to do with GVWR. I suspect it's the same with your truck. This is the thread: https://www.ford-trucks.com/forums/1...610-in-ny.html |
1978 LN600
(Post 15808601)
N61DVCC7679
How about this one? i just bought this truck and any info would be great!! N61 = LN600 (gas). D = 330 2V H/D FT Engine. V = Kentucky Truck Assembly Plant. CC7679 = 1978. The TYPE/GVW aka MODEL code stamped on the Warranty Plate (thru 1979) defines the GVWR |
