SEM Paint Information
I had a massive curiosity about SEM paints. So I gathered all the information I could from this forum and the SEM website, and wanted to put it all in one place. The stuff posted is what I believe to be most useful and/or most used on this forum.
SEM Detail: How-To Thread: This thread explains the process to get the plastic ready. Ford Paint Chips 1980-1986: This thread contains the Factory paint colors, interior and exterior. Before & After 1985 Truck: How much of a difference SEM actually makes. SEM Aerosol Color Chart: Colors straight from SEM. Due to the sheer amount of info, and the restriction of 30,000 characters per post, I had to split the info into sections. Section 1: Preparation Products Section 2: Factory Pack Paints Section 3: EZ Coat Paints Section 4: Aerosol Color Coat |
Section 1) Prep Products
These are the things that SEM says you should use before you paint, and it’s a good idea. (The SEM soap has been substituted with regular dish soap) Here is a suggested method of prepping:
Originally Posted by capri debris
The main problem people have is almost every car at some time has some Armorall wiped on it, so NOTHING will stick until it's all gone. Armorall is tough to get off, so that is why AJAX is so helpful.
1. Soap and water... rinse. 2. AJAX and water... rinse. 3. Mineral spirits... rinse. 4. AJAX again with a green Scotchbrite pad.... rinse, rinse and then rinse again. 5. Wipe with alcohol... rinse. 6. Wipe with plastic prep 7. Apply Adhesion Promoter 8. While Adhesion Promoter is still wet, paint in several light coats on a warm, sunny, low humidity day allowing it to dry between coats. 9. Let it sit for SEVERAL days (or weeks) before trying to handle the pieces. 10. Cleaning and rinsing is VERY important... you can NEVER get it TOO clean. SEM Soap 39362 Plastic & Leather Prep 38353 Adhesion Promoter 39863 Vinyl Prep 38343 |
Section 2) “Factory Pack” Paint
SEM states: “A unique and time saving basecoat for jambs, cut-ins, small accessories, and touch ups.” Not as extensive in color options as Color Coat. Made from urethane, in 16oz spray cans. It is reported to have an excellent spray pattern. Ford Colors: <TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 219.65pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=293><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>PART # </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>COLOR </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap> CODE </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19013 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>SILVER FROST </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>TS </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19023 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>WHITE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>YZ </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19033 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>DK SHADOW GRAY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>CX </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19043 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>REDFIRE PEARL </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>G2 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19053 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>TORREADOR RED MET </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>FL </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19063 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>PUEBLO GOLD </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>G3 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19073 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>VERMILLION </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>E4 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 8"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19083 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>DK BLUE PEARL </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>DX </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 9"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19093 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>SILVER MET </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>YN </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 10; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 45.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=61 noWrap>19103 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.75in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=168 noWrap>BLACK </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>UA </TD></TR></TBODY></TABLE> |
Section 3) EZ Coat Paint
SEM states: “A unique direct to metal coating that matches the color and gloss of factory primer and e-coat colors.” Comes in 12oz cans, and not sure why you would use half of these colors… <TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 155pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=207><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>PART # </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>COLOR </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62213 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>BLACK </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62223 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>OLIVE GREEN </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62233 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>LIGHT GREEN </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62243 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>GRAY </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62253 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>TAN </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62263 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>OLIVE BROWN </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 7; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>62273 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 107pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=143 noWrap>WHITE </TD></TR></TBODY></TABLE> |
Section 4.1) Color Coat
SEM states: “A specialty elastomeric coating formulated to restore or change the color of most vinyl surfaces, flexible and rigid plastics, carpet and velour. Not a dye, but a fade resistant flexible and permanent coating.” Basically, it’s really useful paint. Comes in 16oz cans. <TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 329.15pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=439><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>PART # </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>DESCRIPTION </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap># of Times used on 1980-1986 Trucks </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>Year of Truck </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>13003 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>HIGH GLOSS CLEAR </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>13013 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SATIN GLOSS CLEAR </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>13023 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LOW LUSTER CLEAR </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15003 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>PHANTOM WHITE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15013 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LANDAU BLACK </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1…………………. </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>85 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15023 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>CORDOVAN BROWN </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15033 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SADDLE TAN </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1…………………. </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>83 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 8"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15043 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SHADOW BLUE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 9"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15053 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>GRANITE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 10"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15063 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>BURGUNDY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 11"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15083 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SILVER </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 12"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15093 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LIGHT BUCKSKIN </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 13"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15103 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SUPER WHITE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 14"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15113 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>FIRETHORN RED </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 15"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15123 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SANTA FE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 16"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15143 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SANDSTONE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 17"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15163 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>PRESIDIO </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 18; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15173 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>CAMEL </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>3…………………. </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>84, 85, 85 </TD></TR></TBODY></TABLE> |
Section 4.2) Color Coat
<TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 329.15pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=439><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>PART # </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>DESCRIPTION</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap># of Times used on 1980-1986 Trucks</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>Year of Truck</B> </TD></TR></TBODY></TABLE></B> <TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 329.15pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=439><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15183 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>WARM GRAY</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15213</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>BLUEMIST</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15223</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>CASTELLA</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15233</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>GLOSS BLACK</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15243</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SATIN BLACK</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>2………………….</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>80, 81</B> </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15253</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>TITANIUM METALLIC</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1………………….</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>83</B> </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15273</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>NAPA RED</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15283</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>PESCADERO SAND</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 8"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15303</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>GRAPHITE</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 9"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15313</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>WHITE</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 10"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15323</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>PALOMINO</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1………………….</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>84</B> </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 11"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15353</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LIGHT TITANIUM</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 12"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15363</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>PORTOLA RED</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1………………….</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>85</B> </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 13"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15373</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>FLAME RED</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 14"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15393</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MEDIUM GRAY</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 15"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15413</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>THOMAS BUS GRAY</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 16"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15453</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>GLOSS WHITE</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 17"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15483</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>BLUEBIRD BROWN</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 18; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15603</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SAILCLOTH WHITE</B> </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR></TBODY></TABLE></B> |
Section 4.3) Color Coat
<TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 329.15pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=439><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>PART # </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>DESCRIPTION </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap># of Times used on 1980-1986 Trucks </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>Year of Truck </TD></TR></TBODY></TABLE> <TABLE style="MARGIN: auto auto auto 4.75pt; WIDTH: 329.15pt; BORDER-COLLAPSE: collapse; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 5.4pt 0in 5.4pt" class=MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=439><TBODY><TR style="HEIGHT: 15pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15643 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>PACIFIC BLUE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1…………………. </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>80 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15713 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LADERA </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15723 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MONTEREY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15753 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LIGHT OAK </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15763 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>STORM GRAY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15793 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>SHALE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15803 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>OPEL GRAY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15813 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MED DK PEWTER </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 8"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15823 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LT PARCHMENT </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 9"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15833 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>KHAKI </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 10"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15843 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MED PARCHMENT </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 11"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15853 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>IVORY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 12"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15863 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>LT NEUTRAL </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 13"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15873 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MED SLATE GRAY </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 14"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15883 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MED NEUTRAL </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 15"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>15893 </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>MED PRAIRIE TAN </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap></TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 16"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>????? </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>CANYON RED </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1…………………. </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>85 </TD></TR><TR style="HEIGHT: 15pt; mso-yfti-irow: 17; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 48pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=64 noWrap>????? </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 123.65pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=165 noWrap>WEDGEWOOD BLUE </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 1.25in; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=120 noWrap>1…………………. </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 67.5pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0in" vAlign=bottom width=90 noWrap>81 </TD></TR></TBODY></TABLE> |
Holy paint chips, Batman, this is some impressive data!! Thanks for compiling it.
We have recently ordered some of the Classic Coat to attempt a vinyl flooring restoration on the '72 Commando. (Such flooring being out of production and impossible to find.) Read a great article on repairing vinyl mats from the underside using pieces of inner tube and contact cement. We also decided to change from Black, which hasn't been black for a couple of decades, to Medium Graphite, which will show a bit less dirt. |
Good to hear from you, WJ. We missed you this past weekend.
Please excuse the hijack! |
Originally Posted by WilleyJoe.62
(Post 15698679)
Originally Posted by 1986F150six
(Post 15698969)
Please excuse the hijack! Not hijacked at all, WJ is an awesome member. |
Thanks fellas. And dang, I thought I read the thread as Classic Coat. :-huh
Maybe SEM just has too many paints ... :D |
(Post 15699827)
BTW, in my procurement search, I found that Summit Racing appears to carry the entire line of SEM products. It's been easier and easier lately to hit that magical $99/Free Shipping mark ...
SEM Paint & More Products at Summit Racing |
