Ford 226 Oil Pressure on a Rebuild
Hello,
So I finally got around to starting up my recently rebuilt ford 226. Upon starting it up I noticed that the oil pressure went up to 80 pounds at idle. But on giving her a little gas oil pressure went beyond the gauge readings, looks like its well beyond 100 psi. Oil pressure remains beyond 100. I am using a mechanical gauge and today hooked up a second one to confirm the readings from the first, it does the same thing. What could be causing this?? I have only ran the motor 2 times and around 5 min each time. :-huh:-huh:-huh |
I'd guess your oil pressure relief valve is stuck shut. Lots of details on it in this old thread:
https://www.ford-trucks.com/forums/1...aight-6-a.html |
what weight oil are you using?
Thanks for the tip Ross.
I will check which break in oil I am running tonight. Thanks |
I am running 15 w-50 break in oil by Joe Gibbs.
Before trying to remove the pressure relief valve I went out back to practice on my old block. I broke 2 screw drivers. What is the best way to remove this valve?? Looks like I may need a super size screw driver? I only fear that I may chew up the slotted end before I comes out. Any ideas??? I was also thinking may be before removing it I try and add some wd40 into the plug right above to try and loosen it up. What do you guys think? |
WD-40 isn't a good penetrant; for an oil system component all gummed up, I'd try straight acetone or lacquer thinner. They make "screwdriver bits" for 3/8" ratchets/breaker bars, likely what you'll need. The hot wrench may help too.
to remove that valve I used a big 3/8 flathead screwdriver, the biggest one they sell at Lowes in conjunction with a little heat from a mapp torch. The same does not work on the galley plugs so I have a 1/2 flathead socket coming for the impact gun.
Jb |
Thanks for your help!
So as you can see from the picture, the valve stem is jammed and will not move in the relief valve that I just removed from the rebuild block.
I removed the other relief valve from the 226 block i have on the side of my house. Thanks Everyone for the tip, looks like the relief valve is stuck closed. I will try to loosen it up and clean it, or just use the one from my other block. https://cimg1.ibsrv.net/gimg/www.for...276c12c7cd.jpg |
PSI now at 50, I only ran it for 1 minute to see if it would go to 100.
Thanks God it Did Not! |
Vegas,
What RPM did you observe the 50? And did you note any other readings after the fix at any other RPM's? Reason for asking, I'm wondering what I could expect to see on my 226 if it were rebuilt. thanks for any info, Tom |
Hi Buddy,
I am sorry I cannot give much more details since I only ran the engine for about 1 minute. It reached approx 50 pounds at cold start. I do not have an RPM gauge set up, sorry. I will update this post as I go and let you know how the oil pressure thing goes. |
