Exhaust Manifold Gaskets.
Hi there guys I have noticed my extractors, manifolds, have a leak, I've bought the new gaskets and a torque wrench as well, I've never done any work like that before and I'm just wandering if anyone can give me some tips on getting the perfect seal, ect.
Also I'm not sure what to Torque the bolts at? Thank you very much 😀 |
John - First, welcome to FTE!
Second, what engine? The torque value may vary by engine. Third - extractors??? Where in the UK do you live? |
Looks like Australia....
Originally Posted by ctubutis
(Post 15488690)
From my experience the trucks in England were taken over there by U.S. Military personnel. We lived close to a U.S. Air Force base and it wasn't unusual to see them on the road - but if that was a B road they looked huge! Anyway, the number of these trucks in England is pretty small. |
Hi there guys I'm in Australia, and my truck is 1981 f100 LWB, 351w 5.8L
Are you sure it's a 351W? How many bolts hold on each valve cover? Over here, 1981 would have had a 351M and I know you guys had the 351C in trucks, which was never offered in trucks over here.
I'll look up exhaust manifold torque values tomorrow on both engines. But, I agree with Chris that it is likely to be an M - 8 bolts on the tappet covers and the thermostat sits in the block. (An upside-down M has 6 bolts/cover and the 'stat sits in the intake manifold.)
Sorry boys my bad the rocker covers have 8 bolts. I'm not very experienced, I'm only 16, the truck was my grandpas who is no longer with me, he bought the truck brand new from the dealership and he has had it ever since then, I just took it up as a project recently, thanks for your help! So 8 bolts means it's a Cleveland engine or a Windsor ?
https://cimg5.ibsrv.net/gimg/www.for...a42b478fed.jpg. That's the truck! |
Nice ride!
I agree with maytag906! Welcome to the forum.
8 bolts means it's an M or a C but definitely not a W.
The M evolved from the C but I don't know that you guys had an M over there; at least, I have never heard of such a configuration on a truck built in AU. Do some homework on the differences between the M and C (and maybe the W just for the halibut). |
A Windsor takes 18 - 24 ft-lbs to correctly tighten the exhaust manifold bolts, but a C/M/400 takes more that twice that: 28 - 33 ft-lbs. That's according to Ford's 1981 Light truck Shop Manual.
Here's some good reading about the C/M/400 engines: Bubba's M-Block Ford V8 Workshop. |
Thank you, so you guys say it's a Cleveland motor, how can you tell if it's C or a W
Originally Posted by Johno.h
(Post 15493185)
6 bolts holding the valve covers on = W ~~ Two vertically-oriented bolts holding the fuel pump on = M or C Two horizontally-oriented bolts holding the fuel pump on = W ~~ You need to determine if C or M |
