Codes PO171/PO174
1997 Ford F150XL 2WD 4.2LT.
Today I replaced the 2 upstream O2 sensors and I got it running,But still has a slight miss.And still running like crap. And I tried to start it an hour ago and it won't start,It acts like it wants to start,But won't. This is what I have done in the last 4 months: New; Air filter Mass Airflow Sensor Spark Plugs Spark plug Wires Fuel Filter(was very dirty when draining fuel from old filter) PCV and Elbow And 2 years ago,I replaced the EGR Valve(new),EGR Vacuum Solenoid(new), and DPFE Sensor(used) BTW,I sprayed some Carb and Choke cleaner around the intake and vacuum lines and no change in the idle pitch. |
BTW,I sprayed some Carb and Choke cleaner around the intake and vacuum lines and no change in the idle pitch. Today I replaced the 2 upstream O2 sensors I tried to start it an hour ago and it won't start,It acts like it wants to start,But won't. The 4.2 of that era was very prone to intake gasket and isolator bolt leaks. Verify you have the correct fuel pressure. Insufficient fuel volume at pressure is one of the possible causes of your fault codes. Use your scan tool and monitor either the short term fuel trims or the upstream O2 sensor voltages and do your spraying around the intake. When the flammable gets sucked into the intake, you'll see it. |
Okay,I'll have to wait.Money is lower now and can you recommend a cheap but good code scanner?The last codes I had done at O'Reilly auto parts.
Since I put the O2 Sensors in the check engine light has not come back on. And I just went out and tried to start it and it did start(Idle very rough)and it smelled very rich while running. |
Hey anyone,I noticed my air intake is the aluminum(not plastic).Does this aluminum air intake still leak like the plastic ones?
can you recommend a cheap but good code scanner? |
Originally Posted by projectSHO89
(Post 14900169)
Do you have an Android phone or tablet?
You'll need BT.
Get a BT-OBDII adapter off ebay, about $25. Buy the Torque App, for less than $10. You'll then have what you need |
(Post 14900629)
You'll need BT.
Get a BT-OBDII adapter off ebay, about $25. Buy the Torque App, for less than $10. You'll then have what you need The Check Engine light has not come back on yet. I went out to start the truck and got a hard start(took 4 try's). And when it did start,It backfired and stumbled all the way to the store.Backfired and lose of power until I floored the throttle. Still running like crap. |
That usually means you have a severe vacuum leak or a weak fuel supply.
(Post 14900629)
You'll need BT.
Get a BT-OBDII adapter off ebay, about $25. Buy the Torque App, for less than $10. You'll then have what you need Do you mean Torque by:Ian Hawkins?
(Post 14900827)
Ok,Thanks again.So I might have to wait for the bluetooth scanner to see for sure. This really sucks and this truck is our only ride. |
Well here is what the codes are now P1537/P1538;Intake Manifold Runner Control Stuck Open.
Now the truck has not run for about 2 weeks.Afraid to drive it. |
Does my truck have 2 of these Intake Manifold Runner Control?
Code 1531= bank 1.
Code 1538= bank 2. Good luck. |
Originally Posted by Bluegrass 7
(Post 14963542)
Code 1531= bank 1.
