aFe to RiffRaff filter
Hey just thought I'd share some photo's of the filter conversion from an aFe stage 11 style filter to the RiffRaff 6637 filter kit.https://cimg3.ibsrv.net/gimg/www.for...cc50455468.jpg
aFe set up , this filter is very small compared to the RiffRaff 6637 https://cimg6.ibsrv.net/gimg/www.for...69269d67b5.jpg Battery box and air box removed https://cimg0.ibsrv.net/gimg/www.for...0efaf24773.jpg This is roughly how i will set the filter up https://cimg1.ibsrv.net/gimg/www.for...2e6bee47c2.jpg The original battery / air box i cut in half, and just have the front battery compartment and intake panel. https://cimg5.ibsrv.net/gimg/www.for...fae713b1e7.jpg Made a new adapter plate for the intake tube to go through, this will bolt to the side of the battery box side panel. https://cimg6.ibsrv.net/gimg/www.for...6765145fec.jpg This is how the plate looks fitted up , it holds the filter steady. https://cimg0.ibsrv.net/gimg/www.for...36da324658.jpg Fabricating a new bottom for the filter. https://cimg6.ibsrv.net/gimg/www.for...4a7d5d390f.jpg Spot weld and check for fitment. https://cimg7.ibsrv.net/gimg/www.for...bd3abf1789.jpg Fit a panel to separate the battery and filter for the battery. https://cimg0.ibsrv.net/gimg/www.for...00b82f943d.jpg First test fit, had to make some adjustments around the power steering piping. https://cimg1.ibsrv.net/gimg/www.for...5e8d541f03.jpg https://cimg3.ibsrv.net/gimg/www.for...13698bd3f5.jpg Filter elbow tack welded to the new intake panel. https://cimg5.ibsrv.net/gimg/www.for...7765cb5211.jpg Ready for the paint shop. https://cimg5.ibsrv.net/gimg/www.for...7aa656d592.jpg Painting in progress. https://cimg9.ibsrv.net/gimg/www.for...d78781c64d.jpg Filter elbow. https://cimg4.ibsrv.net/gimg/www.for...a379f836fd.jpg First fitment after painting. https://cimg2.ibsrv.net/gimg/www.for...a91e2b2a87.jpg Side of the new filter box , with the elbow in place and intake tube. https://cimg7.ibsrv.net/gimg/www.for...4f34c9575f.jpg Ooops forgot the hole for the filter minder, welded in a 1/8'' 316 flat washer so the grommet will fit snug. https://cimg7.ibsrv.net/gimg/www.for...1c8cea097f.jpg Fitted up , make sure everything is clear , notice i fitted the sensor on the back of the filter box , i did this just because it was there , RR instructions says to cable tie to the wiring loom. https://cimg3.ibsrv.net/gimg/www.for...2818266d30.jpg Try the filter minder . https://cimg2.ibsrv.net/gimg/www.for...7c4cfc1f80.jpg Fitted up and make sure there's clearance all round the filter. https://cimg5.ibsrv.net/gimg/www.for...e76a334724.jpg I did some research o how the filter minder should be fitted and found that there shouldn't be to much length between the tube and the minder , so this is why i fitted it like this. https://cimg1.ibsrv.net/gimg/www.for...dc836fb68d.jpg Finished product. https://cimg2.ibsrv.net/gimg/www.for...832ad313b8.jpg Now for the test run. |
Beautiful job mate!! If it works half as good as it looks it will be excellent.:-X22 Great work.:) |
Looks awesome mate inspires me to neaten up my mess.what is the other riser pipe and radiator cap for? Power steering extension? Im looking for something similar when I do my Ram Assist and that would be right up my alley.
That other riser is for filling the add on water to oil cooler for the transmission, i had some heating issues with the tranny some time ago so i fitted an extra W/O cooler under the truck.
https://cimg1.ibsrv.net/gimg/www.for...35828b3689.jpg W/O cooler and 12 volt pump sit on the T/C xmember.<br/>The filler neck is just to keep this topped up. |
that looks great
I am running the same air filter but with on heat shroud I am getting high egt when towing wood the shroud help in this area do you experience high egt with your set up any info or help wood be good cheers Rod |
If your getting high EGT's you will need to look at what chip if any you have and if you possibly have a boost leak.
What turbo have you got GTP38? |
GTP38R
WW/2 |
comon Rod. u know wat u have to do
Originally Posted by Loaf4000
(Post 15173270)
GTP38R
WW/2 Have you a chip or tuner? What wait are you towing? Fuel pressure? |
