aFe to RiffRaff filter - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 10-22-2014, 06:26 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
Hey just thought I'd share some photo's of the filter conversion from an aFe stage 11 style filter to the RiffRaff 6637 filter kit.
aFe set up , this filter is very small compared to the RiffRaff 6637
Battery box and air box removed
This is roughly how i will set the filter up
The original battery / air box i cut in half, and just have the front battery compartment and intake panel.
Made a new adapter plate for the intake tube to go through, this will bolt to the side of the battery box side panel.
This is how the plate looks fitted up , it holds the filter steady.
Fabricating a new bottom for the filter.
Spot weld and check for fitment.
Fit a panel to separate the battery and filter for the battery.
First test fit, had to make some adjustments around the power steering piping.
Filter elbow tack welded to the new intake panel.
Ready for the paint shop.
Painting in progress.
Filter elbow.
First fitment after painting.
Side of the new filter box , with the elbow in place and intake tube.
Ooops forgot the hole for the filter minder, welded in a 1/8'' 316 flat washer so the grommet will fit snug.
Fitted up , make sure everything is clear , notice i fitted the sensor on the back of the filter box , i did this just because it was there , RR instructions says to cable tie to the wiring loom.
Try the filter minder .
Fitted up and make sure there's clearance all round the filter.
I did some research o how the filter minder should be fitted and found that there shouldn't be to much length between the tube and the minder , so this is why i fitted it like this.
Finished product.
Now for the test run.
Old 10-23-2014, 03:04 AM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is online now
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
Beautiful job mate!!
If it works half as good as it looks it will be excellent.
Great work.
Old 03-03-2015, 03:43 PM
WA F250's Avatar
WA F250
WA F250 is offline
WA F250 is starting off with a positive reputation.
Looks awesome mate inspires me to neaten up my mess.what is the other riser pipe and radiator cap for? Power steering extension? Im looking for something similar when I do my Ram Assist and that would be right up my alley.
Old 03-03-2015, 04:42 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
That other riser is for filling the add on water to oil cooler for the transmission, i had some heating issues with the tranny some time ago so i fitted an extra W/O cooler under the truck.
W/O cooler and 12 volt pump sit on the T/C xmember.<br/>The filler neck is just to keep this topped up.
Old 03-07-2015, 08:39 PM
Loaf4000
Loaf4000 is offline
Loaf4000 is starting off with a positive reputation.
that looks great
I am running the same air filter
but with on heat shroud
I am getting high egt when towing
wood the shroud help in this area
do you experience high egt with your set up
any info or help wood be good
cheers
Rod
Old 03-09-2015, 01:33 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
If your getting high EGT's you will need to look at what chip if any you have and if you possibly have a boost leak.
What turbo have you got GTP38?
Old 03-13-2015, 08:37 AM
Loaf4000
Loaf4000 is offline
GTP38R
WW/2
Old 03-14-2015, 08:08 PM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
comon Rod. u know wat u have to do
Old 03-15-2015, 03:49 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Originally Posted by Loaf4000 View Post
GTP38R
WW/2
Make yourself up a simple boost leak tester out of pvc pipe
then test for leaks, you will need a spray bottle full of soapy water to spray over the ic pipes and basically any where that air from the intake can go.
Have you a chip or tuner?
What wait are you towing?
Fuel pressure?
sstephanuik
225
03-07-2018 06:22 PM
ssoundwave
2017+ Super Duty
145
09-07-2017 06:02 AM
17PlatinumSFL
2017+ Super Duty
20
03-28-2017 09:08 PM
Native Images
2015+ F150
02-13-2017 07:31 AM
Quick Reply: aFe to RiffRaff filter
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
